maybee |
December 21, 2013 10:13 |
multiphaseEulerFoam: method mag(...) withing method solveAlphase()
hi,
within method solveAlphas in file multiphaseSystem.C of the multiphaseEulerFoam solver is found:
//SNIPPET 1
(mag(phi_) + mag(phase1.phi() - phase2.phi()))/mesh_.magSf()
where phi_ is "const surfaceScalarField& phi_ in multiphasesystem.H" and therefore the first mag method is:
//SNIPPET 2
template<class Type, template<class> class PatchField, class GeoMesh>
323*tmp<GeometricField<scalar, PatchField, GeoMesh> > mag
324*(
325* const GeometricField<Type, PatchField, GeoMesh>& gf //const surfaceScalarField& phi_
326*)
327*{
328* tmp<GeometricField<scalar, PatchField, GeoMesh> > tMag
329* (
330* new GeometricField<scalar, PatchField, GeoMesh>
331* (
332* IOobject
333* (
334* "mag(" + gf.name() + ')',
335* gf.instance(),
336* gf.db(),
337* IOobject::NO_READ,
338* IOobject::NO_WRITE
339* ),
340* gf.mesh(),
341* gf.dimensions()
342* )
343* );
344*
345* mag(tMag(), gf);
346*
347* return tMag; //tmp<GeometricField<scalar, PatchField, GeoMesh> > tMag
348*}
In line 345 is found the second mag(...) method:
//SNIPPET 3
312 void mag
313 (
314 GeometricField<scalar, PatchField, GeoMesh>& gsf,
315 const GeometricField<Type, PatchField, GeoMesh>& gf
316 )
317 {
318 mag(gsf.internalField(), gf.internalField()); //QUESTION 1
319 mag(gsf.boundaryField(), gf.boundaryField()); //QUESTION 2
320 }
with the third and the fourth mag(...) methods
//SNIPPET 4
Foam::GeometricField<Type, PatchField, GeoMesh>::internalField() //QUESTION 1
674 {
675 this->setUpToDate();
676 storeOldTimes();
677 return *this;
678 }
and
//SNIPPET 5
Foam::GeometricField<Type, PatchField, GeoMesh>::boundaryField() //QUESTION 2
686 {
687 this->setUpToDate();
688 storeOldTimes();
689 return boundaryField_; //GeometricBoundaryField boundaryField_
690 }
My questions are about the three last codesnippets (SNIPPET 3-5):
QUESTION 1:
If "internalfield()" returns the updated object it is called on and afterwards mag(...) is called in line 318 of SNIPPET 3 wouldn't this cause an endless loop since the SAME method mag(...) like at the beginning of SNIPPET 3 would be called again and again?
QUESTION 2:
method mag(...) in line 319 of SNIPPET 3 should be
void mag(FieldField<Field, scalar>& sf, const FieldField<Field, Type>& f) //sf: GeometricBoundaryField boundaryField_ of GeometricField of tmp<GeometricField<scalar, PatchField, GeoMesh> > tMag
189*{ //f: GeometricBoundaryField boundaryField_ of const surfaceScalarField& phi_
190* forAll(sf, i)
191* {
192* mag(sf[i], f[i]);
193* }
194*}
Where can I find the mag(...) method that in this case should take two scalars as input parameters (as I suppose)?
