CHEMKIN file not understood by OpenFOAM
can somebody who is familiar with the CHEMKIN file format please help with the following problem? I am trying to use the file [1] as thermo.dat input for the combustion solver. Although [2] says that the file is in CHEMKIN format, there seems to be at least one major incompatibility compared to the format description at [3]: For example, lines 34-38 of [1] read: Code:
oh 8/12/99 thermh 1o 1 0 0g 300.000 5000.000 1357.000 01 Anyone familiar with the CHEMKIN format, who can help? Thank you Helge [1] https://www-pls.llnl.gov/data/docs/s...symp_therm.txt [2] https://www-pls.llnl.gov/?url=scienc...uced_mechanism [3] http://www2.galcit.caltech.edu/EDL/p...s/chemkin.html |
I cannot really help you, but I can confirm the problem. ;)
Reading CHEMKIN mechanisms or thermo files with OpenFOAM is an adventures exercise. :mad: I barely got any of the mechanisms from LLNL to work with OpenFOAM. A workaround that I used for some smaller mechanisms was to convert the CHEMKIN files to OpenFOAM-format with Code:
chemkinToFoam On the plus side you get a "human readable" mechanism/thermo file that works for sure with OpenFOAM. And maybe a last note concerning the thermo files: The common temperature of the two Cp/h/s polynomial (Tcommon) needs to be the same for all species. If this is not the case for your thermo data you need to refit the polynomials. Cheers, Armin |
Oh and you can find a quite good description of the thermo data, i.e. NASA or JANAF polynomials, here:
http://www.me.berkeley.edu/gri_mech/data/nasa_plnm.html |
