Adding a new member function to SingleStepCombustion
Old   February 15, 2013, 03:37
Default Adding a new member function to SingleStepCombustion
Tatu Pinomaa
tatu is on a distinguished road
Hi!
I'm trying to add a new method to singleStepCombustion. The goal is to output reaction rate matrix for a specie transport equation, where the solved field is rho*Yi, instead of bare Yi (mass fraction of specie i). This is done for a modified rhoCentralFoam to handle specie transport. I thought this could be done by simply implementing the member function in singleStepCombustion.C as follows:
template<class CombThermoType, class ThermoType>
Foam::tmp<Foam::fvScalarMatrix>
singleStepCombustion<CombThermoType, ThermoType>::Rrho
    const volScalarField& Y,
    const volScalarField& rhoY
) const
    const label specieI = this->thermo_->composition().species()[Y.name()];
    const volScalarField wSpecie
        wFuel_*singleMixture_.specieStoichCoeffs()[specieI]
    return wSpecie + fvm::Sp(0.0*wSpecie, rhoY);
Then I would add the function definition to singleStepCombustion.H:
virtual tmp<fvScalarMatrix> Rrho(const volScalarField& Y, const volScalarField& rhoY) const;
And finally add the definition to combustionModel.H:
virtual tmp<fvScalarMatrix> Rrho(const volScalarField& Y, const volScalarField& rhoY) const = 0;
I understand that this is all I have to do: I can't find other dependencies where the member function should be defined. Then I compile the combustionModel folder (wmake libso), and no errors or warnings are produced. If I then try to call the new member function with combustion->Rrho(Yi,rhoYi) inside the solver (analogically to working call combustion->R(Yi) ), and compile (wmake), I get the following error:
YEqn.H: In function ‘int main(int, char**)’:
YEqn.H:73:30: error: ‘class Foam::combustionModels::psiCombustionModel’ has no member named ‘Rrho’
I don't understand why the new member function isn't recognized. Did I forgot to add the member function definition somewhere? I've tried to look through everywhere I think it might be missing. I'm using OF 2.1.1, but the files from 2.1.x I added should be pretty much identical.
Tatu
tatu is offline   Reply With Quote
Old   January 8, 2014, 23:54
Thamali
Thamali is on a distinguished road
Hi tatu,
Did you solve your problem,although it is a long time to keep a problem?
If so I have a question for you.
Thanks.
Thamali
Thamali is offline   Reply With Quote
[blockMesh] error message with modeling a cube with a hold at the center hsingtzu OpenFOAM Meshing & Mesh Conversion 2 March 14, 2012 09:56
issue compiling new turbulence model perplexed user OpenFOAM Programming & Development 1 January 13, 2012 03:40
LiencubiclowRemodel nzy102 OpenFOAM Bugs 14 January 10, 2012 08:53
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
[OpenFOAM] LibvtkFoamso fred ParaView 2 November 18, 2005 19:01
