Parallel run crashes when trying to loop into faces of a patch
Old   October 3, 2013, 15:10
Default Parallel run crashes when trying to loop into faces of a patch
George D.
dgeorge8286 is on a distinguished road
Hello everybody. I am trying to calculate a flux using an expression that is related to the value of pressure in 2 different patches of my domain.
To find the label of the patches, I am using:
label patchID1 = mesh.boundaryMesh().findPatchID("side1");
const polyPatch& cPatch1 = mesh.boundaryMesh()[patchID1];
label patchID2 = mesh.boundaryMesh().findPatchID("side2");
const polyPatch& cPatch2 = mesh.boundaryMesh()[patchID2];
This works fine. Then:
forAll(cPatch1, facei)
J.boundaryField()[patchID1][facei] = p.boundaryField()[patchID1][facei] - p.boundaryField()[patchID2][facei];
While in serial this works perfectly, in parallel the solver crashes. the two patches have the same number of faces. Can anybody help me in this?
I inspect that this is related to the communication of the processors but I am not sure how to fix it.
Thank you in advance.
dgeorge8286 is offline   Reply With Quote
Old   October 4, 2013, 14:27
ngj
Niels Gjoel Jacobsen
ngj will become famous soon enoughngj will become famous soon enough
Hi George,
I would suspect that the decomposition is such that you have different number of faces on the two patches on each processor. Try to investigate processor*/constant/boundary, and you will probably see that the number of faces on the two patches is not the same per processor.
Another thing, which you might want to consider carefully, is that right now you assume a matching ordering of the faces. In general cases with might not be the case.
Kind regards,
Niels
Please note that I do not use the Friend-feature, so do not be offended, if I do not accept a request.
ngj is offline   Reply With Quote
Old   October 4, 2013, 15:27
George D.
Hi Niels,
Thank you very much for your response. Indeed it is the way you described it, however the option preservePatches in decomposeParDict doesn't seem to help.
George
Old   February 10, 2014, 18:29
Joachim Herb
jherb is on a distinguished road
Probably too late, but nevertheless: Both patches (side1, side2) have to calculated by the same processor. So I guess preservePatches just guarantees that each patch is calculated by one processor but not all together. You might be able to do the calculation for each patch on an (arbitrary) processor and then use Pstream::scatter to exchange the information between the processors.
jherb is offline   Reply With Quote
Old   February 11, 2014, 10:18
NaiXian Leslie Lu
LESlie is on a distinguished road
Which OpenFOAM version are you using?
Cheers,
Leslie LU
LESlie is offline   Reply With Quote
Old   February 11, 2014, 10:21
NaiXian Leslie Lu
Originally Posted by ngj View Post
Hi George,
Kind regards,
Niels
Hi Niels,
How does one get face IDs of a polyPatch? I've just posted a thread http://www.cfd-online.com/Forums/ope...-boundary.html
and reading your comments I feel that you might have the answer. Thanks in advance!
Cheers,
Leslie LU
y+ and u+ values with low-Re RANS turbulence models: utility + testcase florian_krause OpenFOAM 114 August 23, 2023 05:37
error in parallel run immortality OpenFOAM Running, Solving & CFD 7 January 1, 2013 13:35
[blockMesh] Cyclic BC's: Possible face ordering problem? (Channel flow) sega OpenFOAM Meshing & Mesh Conversion 3 September 28, 2010 12:46
Problem with rhoSimpleFoam matteo_gautero OpenFOAM Running, Solving & CFD 0 February 28, 2008 06:51
Multicomponent fluid Andrea CFX 2 October 11, 2004 05:12
