Creating field of strings with "mesh-structure"
Old   February 13, 2014, 05:03
Default Creating field of strings with "mesh-structure"
maybee is on a distinguished road
hi,
I need to create a field that consists of a function (string) for each cell of the current geometry like of type
GeometricField<string, fvPatchField, volMesh>
The field should have the structure of the current mesh. Is this possible and how would I do it?
I've read about the classes "geometricField" and "dimensionedField", but I am not sure if it s possible and how to do it.
maybee is offline   Reply With Quote
Old   February 13, 2014, 13:49
ngj
Niels Gjoel Jacobsen
ngj will become famous soon enoughngj will become famous soon enough
Hi Maybee,
It sounds a bit weird, because I am pretty sure that the boundary field is not defined for strings. Do something along the following lines:
List<string> stringField(mesh.C().internalField().size());
forAll (stringField, stringi)
    // Populate with correct string
Kind regards,
Niels
Please note that I do not use the Friend-feature, so do not be offended, if I do not accept a request.
ngj is offline   Reply With Quote
Old   February 14, 2014, 09:49
thx for the answer - i will check this later when I have to implement this into my code.
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 06:20
Problem in running ICEM grid in Openfoam Tarak OpenFOAM 6 September 9, 2011 17:51
Problem with rhoSimpleFoam matteo_gautero OpenFOAM Running, Solving & CFD 0 February 28, 2008 06:51
Phase locked average in run time panara OpenFOAM 2 February 20, 2008 14:37
Creating a mesh of the flow field in GAMBIT Vidya Raja FLUENT 0 October 3, 2005 09:53
