shipman |
March 17, 2014 20:39 |
hi
Dear Alexey,
Finally, program gave again following floating point error:confused:. Mass flow, velocity inside of nozzle seem OK, but at the inlet pressure are increasing so excessively.
Also inside of error i recognized that time step cont. error became crazy?? what is the meaning of this error and how can i correct it?
Thanks in advance.
B
time step continuity errors : sum local = 4.64985e+125, global = -7.72928e+121, cumulative = -1.28369e+122
ERROR:
HTML Code:
Courant Number mean: 1153.13 max: 617400
deltaT = 2.1961e-18
--> FOAM Warning :
From function Time::operator++()
in file db/Time/Time.C at line 1010
Increased the timePrecision from 8 to 9 to distinguish between timeNames at time 0.000458572
Time = 0.000458572308
DILUPBiCG: Solving for alpha1, Initial residual = 0.186596, Final residual = 0.000478897, No Iterations 1
Liquid phase volume fraction = 0.999853 Min(alpha1) = 0.352503 Max(alpha1) = 1
DILUPBiCG: Solving for epsilon, Initial residual = 1, Final residual = 1.78371e-10, No Iterations 2
DILUPBiCG: Solving for k, Initial residual = 1, Final residual = 1.90975e-07, No Iterations 2
PIMPLE: iteration 1
GAMG: Solving for p_rgh, Initial residual = 0.996129, Final residual = 0.00234635, No Iterations 1
GAMG: Solving for p_rgh, Initial residual = 5.3641e-05, Final residual = 5.29413e-10, No Iterations 1
time step continuity errors : sum local = 0.213357, global = 1.01812e-06, cumulative = 8.80345
GAMG: Solving for p_rgh, Initial residual = 0.000155482, Final residual = 7.27544e-08, No Iterations 1
GAMG: Solving for p_rgh, Initial residual = 0.00180428, Final residual = 3.9623e-06, No Iterations 1
time step continuity errors : sum local = 10447.6, global = 8.63117e-07, cumulative = 8.80345
PIMPLE: iteration 2
GAMG: Solving for p_rgh, Initial residual = 0.00207729, Final residual = 6.19547e-05, No Iterations 1
GAMG: Solving for p_rgh, Initial residual = 0.00286512, Final residual = 0.000244628, No Iterations 1
time step continuity errors : sum local = 3.31121e+09, global = -5.84454, cumulative = 2.95891
GAMG: Solving for p_rgh, Initial residual = 0.116709, Final residual = 0.0062631, No Iterations 1
GAMG: Solving for p_rgh, Initial residual = 0.104965, Final residual = 0.00992775, No Iterations 1
time step continuity errors : sum local = 1.13935e+09, global = -2.36284e+06, cumulative = -2.36284e+06
PIMPLE: iteration 3
GAMG: Solving for p_rgh, Initial residual = 0.159014, Final residual = 0.00972769, No Iterations 1
GAMG: Solving for p_rgh, Initial residual = 0.939243, Final residual = 0.0262975, No Iterations 2
time step continuity errors : sum local = 1.37437e+15, global = -1.1007e+14, cumulative = -1.1007e+14
GAMG: Solving for p_rgh, Initial residual = 0.139423, Final residual = 0.00878953, No Iterations 1
GAMG: Solving for p_rgh, Initial residual = 0.831211, Final residual = 0.0467336, No Iterations 1
time step continuity errors : sum local = 3.92446e+16, global = -8.8333e+13, cumulative = -1.98403e+14
PIMPLE: iteration 4
GAMG: Solving for p_rgh, Initial residual = 0.242785, Final residual = 0.0136361, No Iterations 1
GAMG: Solving for p_rgh, Initial residual = 0.973402, Final residual = 0.054481, No Iterations 1
time step continuity errors : sum local = 4.48943e+23, global = -5.0509e+19, cumulative = -5.05092e+19
GAMG: Solving for p_rgh, Initial residual = 0.157715, Final residual = 0.00695594, No Iterations 1
GAMG: Solving for p_rgh, Initial residual = 0.346942, Final residual = 0.0191784, No Iterations 1
time step continuity errors : sum local = 4.63282e+23, global = -7.63235e+19, cumulative = -1.26833e+20
PIMPLE: iteration 5
GAMG: Solving for p_rgh, Initial residual = 0.181717, Final residual = 0.0104671, No Iterations 1
GAMG: Solving for p_rgh, Initial residual = 0.97619, Final residual = 0.0542755, No Iterations 1
time step continuity errors : sum local = 8.67454e+30, global = -9.74491e+26, cumulative = -9.74491e+26
GAMG: Solving for p_rgh, Initial residual = 0.170678, Final residual = 0.00688831, No Iterations 1
GAMG: Solving for p_rgh, Initial residual = 0.324195, Final residual = 0.0186419, No Iterations 1
time step continuity errors : sum local = 8.8706e+30, global = -1.47446e+27, cumulative = -2.44895e+27
PIMPLE: iteration 6
GAMG: Solving for p_rgh, Initial residual = 0.183186, Final residual = 0.0103863, No Iterations 1
GAMG: Solving for p_rgh, Initial residual = 0.976201, Final residual = 0.0542631, No Iterations 1
time step continuity errors : sum local = 1.6764e+38, global = -1.88316e+34, cumulative = -1.88316e+34
GAMG: Solving for p_rgh, Initial residual = 0.170606, Final residual = 0.0068871, No Iterations 1
GAMG: Solving for p_rgh, Initial residual = 0.324194, Final residual = 0.0186373, No Iterations 1
time step continuity errors : sum local = 1.71433e+38, global = -2.84964e+34, cumulative = -4.7328e+34
PIMPLE: iteration 7
GAMG: Solving for p_rgh, Initial residual = 0.183132, Final residual = 0.0103844, No Iterations 1
GAMG: Solving for p_rgh, Initial residual = 0.976203, Final residual = 0.0542605, No Iterations 1
time step continuity errors : sum local = 3.23962e+45, global = -3.63913e+41, cumulative = -3.63913e+41
GAMG: Solving for p_rgh, Initial residual = 0.17059, Final residual = 0.00688685, No Iterations 1
GAMG: Solving for p_rgh, Initial residual = 0.324194, Final residual = 0.0186363, No Iterations 1
time step continuity errors : sum local = 3.31293e+45, global = -5.50695e+41, cumulative = -9.14608e+41
PIMPLE: iteration 8
GAMG: Solving for p_rgh, Initial residual = 0.183121, Final residual = 0.010384, No Iterations 1
GAMG: Solving for p_rgh, Initial residual = 0.976204, Final residual = 0.05426, No Iterations 1
time step continuity errors : sum local = 6.26046e+52, global = -7.03248e+48, cumulative = -7.03248e+48
GAMG: Solving for p_rgh, Initial residual = 0.170587, Final residual = 0.0068868, No Iterations 1
GAMG: Solving for p_rgh, Initial residual = 0.324194, Final residual = 0.0186361, No Iterations 1
time step continuity errors : sum local = 6.40213e+52, global = -1.0642e+49, cumulative = -1.76745e+49
PIMPLE: iteration 9
GAMG: Solving for p_rgh, Initial residual = 0.183118, Final residual = 0.0103839, No Iterations 1
GAMG: Solving for p_rgh, Initial residual = 0.976204, Final residual = 0.0542599, No Iterations 1
time step continuity errors : sum local = 1.20981e+60, global = -1.359e+56, cumulative = -1.359e+56
GAMG: Solving for p_rgh, Initial residual = 0.170587, Final residual = 0.00688679, No Iterations 1
time step continuity errors : sum local = 1.23719e+60, global = -2.05654e+56, cumulative = -3.41554e+56
PIMPLE: iteration 10
time step continuity errors : sum local = 2.33792e+67, global = -2.62622e+63, cumulative = -2.62622e+63
time step continuity errors : sum local = 2.39082e+67, global = -3.97418e+63, cumulative = -6.6004e+63
PIMPLE: iteration 11
GAMG: Solving for p_rgh, Initial residual = 0.976204, Final residual = 0.0542598, No Iterations 1
time step continuity errors : sum local = 4.51794e+74, global = -5.07508e+70, cumulative = -5.07508e+70
time step continuity errors : sum local = 4.62018e+74, global = -7.67996e+70, cumulative = -1.2755e+71
PIMPLE: iteration 12
time step continuity errors : sum local = 8.73076e+81, global = -9.80741e+77, cumulative = -9.80741e+77
time step continuity errors : sum local = 8.92833e+81, global = -1.48413e+78, cumulative = -2.46487e+78
PIMPLE: iteration 13
time step continuity errors : sum local = 1.68719e+89, global = -1.89525e+85, cumulative = -1.89525e+85
time step continuity errors : sum local = 1.72537e+89, global = -2.86802e+85, cumulative = -4.76326e+85
PIMPLE: iteration 14
time step continuity errors : sum local = 3.26043e+96, global = -3.6625e+92, cumulative = -3.6625e+92
time step continuity errors : sum local = 3.33421e+96, global = -5.54234e+92, cumulative = -9.20484e+92
PIMPLE: iteration 15
time step continuity errors : sum local = 6.30066e+103, global = -7.07764e+99, cumulative = -7.07764e+99
time step continuity errors : sum local = 6.44324e+103, global = -1.07104e+100, cumulative = -1.7788e+100
PIMPLE: iteration 16
time step continuity errors : sum local = 1.21758e+111, global = -1.36773e+107, cumulative = -1.36773e+107
time step continuity errors : sum local = 1.24513e+111, global = -2.06974e+107, cumulative = -3.43747e+107
PIMPLE: iteration 17
time step continuity errors : sum local = 2.35293e+118, global = -2.64309e+114, cumulative = -2.64309e+114
time step continuity errors : sum local = 2.40618e+118, global = -3.9997e+114, cumulative = -6.64279e+114
PIMPLE: iteration 18
time step continuity errors : sum local = 4.54695e+125, global = -5.10767e+121, cumulative = -5.10767e+121
PIMPLE: iteration 19
[11] #0 Foam::error::printStack(Foam::Ostream&)[8] #0[10] #0 Foam::error::printStack(Foam::Ostream&)Foam::error::printStack(Foam::Ostream&) in "/opt/openfoam211/platforms/linux64GccDPOpt/li in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAb/libOpenFOAM.so"
[8] #1M.so"
[10] #1 Foam::sigFpe::sigHandler(int) Foam::sigFpe::sigHandler(int) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[11] #1 Foam::sigFpe::sigHandler(int) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[11] #2 in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[10] #2 in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[8] #2 in "/lib/libc.so.6"
[11] #3 Foam::GAMGSolver::scalingFactor(Foam::Field<double>&, Foam::Field<double> const&, Foam::Field<double> const&, Foam::Field<double> const&) const in "/lib/libc.so.6"
[10] #3 Foam::GAMGSolver::scalingFactor(Foam::Field<double>&, Foam::Field<double> const&, Foam::Field<double> const&, Foam::Field<double> const&) const in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[11] #4 Foam::GAMGSolver::scalingFactor(Foam::Field<double>&, Foam::lduMatrix const&, Foam::Field<double>&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, Foam::Field<double> const&, unsigned char) const in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[10] #4 Foam::GAMGSolver::scalingFactor(Foam::Field<double>&, Foam::lduMatrix const&, Foam::Field<double>&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, Foam::Field<double> const&, unsigned char) const in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[11] #5 Foam::GAMGSolver::Vcycle(Foam::PtrList<Foam::lduMatrix::smoother> const&, Foam::Field<double>&, Foam::Field<double> const&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::PtrList<Foam::Field<double> >&, Foam::PtrList<Foam::Field<double> >&, unsigned char) const in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[10] #5 Foam::GAMGSolver::Vcycle(Foam::PtrList<Foam::lduMatrix::smoother> const&, Foam::Field<double>&, Foam::Field<double> const&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::PtrList<Foam::Field<double> >&, Foam::PtrList<Foam::Field<double> >&, unsigned char) const in "/lib/libc.so.6"
[8] #3 Foam::GAMGSolver::scalingFactor(Foam::Field<double>&, Foam::Field<double> const&, Foam::Field<double> const&, Foam::Field<double> const&) const in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[11] #6 Foam::GAMGSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[10] #6 Foam::GAMGSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[11] #7 Foam::fvMatrix<double>::solve(Foam::dictionary const&) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[10] #7 Foam::fvMatrix<double>::solve(Foam::dictionary const&) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[8] #4 Foam::GAMGSolver::scalingFactor(Foam::Field<double>&, Foam::lduMatrix const&, Foam::Field<double>&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, Foam::Field<double> const&, unsigned char) const in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[8] #5 Foam::GAMGSolver::Vcycle(Foam::PtrList<Foam::lduMatrix::smoother> const&, Foam::Field<double>&, Foam::Field<double> const&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::PtrList<Foam::Field<double> >&, Foam::PtrList<Foam::Field<double> >&, unsigned char) const in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[8] #6 Foam::GAMGSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[8] #7 Foam::fvMatrix<double>::solve(Foam::dictionary const&) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libfiniteVolume.so"
[11] #8 in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libfiniteVolume.so"
[10] #8 in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libfiniteVolume.so"
[8] #8
[8] in "/home/yusuke/OpenFOAM/yusuke-2.1.1/platforms/linux64GccDPOpt/bin/RNGinterPhaseChangeFoam"
[8] #9 __libc_start_main[11] in "/home/yusuke/OpenFOAM/yusuke-2.1.1/platforms/linux64GccDPOpt/bin/RNGinterPhaseChangeFoam"
[11] #9 __libc_start_main in "/lib/libc.so.6"
[11] #10
[10] in "/home/yusuke/OpenFOAM/yusuke-2.1.1/platforms/linux64GccDPOpt/bin/RNGinterPhaseChangeFoam"
[10] #9 __libc_start_main in "/lib/libc.so.6"
[8] #10 [11] in "/home/yusuke/OpenFOAM/yusuke-2.1.1/platforms/linux64GccDPOpt/bin/RNGinterPhaseChangeFoam"
[VENUS:21120] *** Process received signal ***
[VENUS:21120] Signal: Floating point exception (8)
[VENUS:21120] Signal code: (-6)
[VENUS:21120] Failing at address: 0x3e800005280
[VENUS:21120] [ 0] /lib/libc.so.6(+0x33af0) [0x7fd7d9a32af0]
[VENUS:21120] [ 1] /lib/libc.so.6(gsignal+0x35) [0x7fd7d9a32a75]
[VENUS:21120] [ 2] /lib/libc.so.6(+0x33af0) [0x7fd7d9a32af0]
[VENUS:21120] [ 3] /opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so(_ZNK4Foam10GAMGSolver13scalingFactorERNS_5FieldIdEERKS2_S5_S5_+0x74) [0x7fd7da9c8664]
[VENUS:21120] [ 4] /opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so(_ZNK4Foam10GAMGSolver13scalingFactorERNS_5FieldIdEERKNS_9lduMatrixES3_RKNS_10FieldFieldIS1_dEERKNS_8UPtrListIKNS_17lduInterfaceFieldEEERKS2_h+0xa6) [0x7fd7da9c87d6]
[VENUS:21120] [ 5] /opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so(_ZNK4Foam10GAMGSolver6VcycleERKNS_7PtrListINS_9lduMatrix8smootherEEERNS_5FieldIdEERKS8_S9_S9_S9_RNS1_IS8_EESD_h+0x126c) [0x7fd7da9caa6c]
[VENUS:21120] [ 6] /opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so(_ZNK4Foam10GAMGSolver5solveERNS_5FieldIdEERKS2_h+0x492) [0x7fd7da9cc182]
[VENUS:21120] [ 7] /opt/openfoam211/platforms/linux64GccDPOpt/lib/libfiniteVolume.so(_ZN4Foam8fvMatrixIdE5solveERKNS_10dictionaryE+0x157) [0x7fd7db548bf7]
[VENUS:21120] [ 8] RNGinterPhaseChangeFoam() [0x432aa8]
[VENUS:21120] [ 9] /lib/libc.so.6(__libc_start_main+0xfd) [0x7fd7d9a1dc4d]
[VENUS:21120] [10] RNGinterPhaseChangeFoam() [0x42b849]
[VENUS:21120] *** End of error message ***
