functionObject to control run time
Old   March 25, 2014, 10:43
Default functionObject to control run time
Marc
marc.immer is on a distinguished road
Hi!
I created a functionObject that helps me run computations on a cluster queue that has a limited run time.
The functionObject stops the solver 10 minutes before the cpu time reaches the cluster time limit using a time.stopAt(Time::saWriteNow); command in the execute() function.
After that it calls a script in the end() call and resubmits the run on the cluster queue.
The Problem is: if the openFoam run finishes normally, the last time step is not written to disk. I would like to solve this.
My idea so far: detect in execute() if the next time step is the last one and call time.stopAt(Time::saWriteNow); However this does not work, as functionObjects are then not called at the last time step. I though of just increasing endTime by one timestep. But I cant access the function Foam::Time::setEndTime from a function object?
I'm happy for any ideas...
Regards
Marc
marc.immer is offline   Reply With Quote
TimeVaryingMappedFixedValue irishdave OpenFOAM Running, Solving & CFD 32 June 16, 2021 06:55
Multiple floating objects CKH OpenFOAM Running, Solving & CFD 14 February 20, 2019 09:08
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 06:20
Help for the small implementation in turbulence model shipman OpenFOAM Programming & Development 25 March 19, 2014 10:08
Unstabil Simulation with chtMultiRegionFoam mbay101 OpenFOAM Running, Solving & CFD 13 December 28, 2013 13:12
