a problem with the source "fvOptions(U)"
hello!
i need help! See you the following UEqn: tmp<fvVectorMatrix> UEqn ( fvm::ddt(U) + fvm::div(phi, U) + turbulence->divDevReff(U) == fvOptions(U) ); I guess the source "fvOptions(U)" is discretised explicit to make sure Diagonally Dominant ! am i right ? or is it implicit ? thanks! |
Looking over some of the fvOption sources:
/src/fvOptions/sources/ it appears that they are all explicit. Although I'm guessing you could always end up implementing whatever you wanted. |
thank you !
