Non-const fvMesh& from BC
Like Tree3Likes
  • 3 Post By tomislav_maric
Old   May 21, 2014, 03:07
Default Non-const fvMesh& from BC
Pablo Higuera
Phicau is on a distinguished road
Hi all,
I would like to create a regular (non-constant) reference to the mesh within a boundary condition. The goal is to register a dictionary, so that it will be available for all the boundary conditions that are alike. However, I have not figured out how to do that, as I can only access const fvMesh& references.
Of course I have an ace up my sleeve and can pre-register the dictionary within the solver, but I'd rather not modify it. This way that the BCs could still be included in controlDict dynamically.
I understand the current implementation is safe, as the initial mesh is not modified in any way. With the great power of modifying the mesh comes great responsibility, but I think I can manage.
Is this even possible without major changes in other basic classes?
Thanks!
Pablo
Phicau is offline   Reply With Quote
Old   May 21, 2014, 06:01
Tomislav Maric
tomislav_maric is on a distinguished road
[QUOTE]
[QUOTE]
Why go outside the boundary condition class at all?
Reading the sentence above it seems that the dictionary is a common data attribute to a bunch of similar boundary conditions.
Make a parent class that is inherited by all similar boundary conditions. Put the dictionary as the private attribute and provide non-const access to it via a protected member function to make it accessible only to the derived boundary conditions. Make the dictionary a sub-dict of the usual BC dictionary input. Read it by the base class constructor. Done. This does not require you to modify any existing code, but to extend the BCs in the appropriate way by introducing your BC class hierarchy.
Phicau, alia and Kummi like this.
When asking a question, prepare a SSCCE.
tomislav_maric is offline   Reply With Quote
Old   May 21, 2014, 07:31
Pablo Higuera
Hi Tomislav,
thanks for all the details, it certainly makes more sense than my approach. I will try that!
Best,
Pablo
Second Derivative Zero - Boundary Condition fu-ki-pa OpenFOAM 11 March 27, 2021 04:28
compressible flow in turbocharger riesotto OpenFOAM 50 May 26, 2014 01:47
Wall bounded values and streamlines Ruli OpenFOAM Post-Processing 5 February 2, 2014 16:45
[snappyHexMesh] Error in SnappyHexMesh gooya_kabir OpenFOAM Meshing & Mesh Conversion 2 October 23, 2013 04:41
LiftDrag coefficient in LES fabian_korn OpenFOAM Post-Processing 1 September 22, 2008 02:34
