Is it possible to combine stress and flow solvers in OpenFOAM? |
April 12, 2014, 15:26 |
Rep Power: 12 |
I am wondering if this has been done already, for example if I want to simulate a complex seal arrangement in which I would like to see how the applied fluid flow pressures deform the sealing element.
I have read that in most cases two separate simulations are ran, one for flow analysis and the other for stress however, in the above application it would require a large number of simulations which would not be practical. |
April 16, 2014, 14:53 |
Rep Power: 12 |
Could someone please tell me if this combination of solvers is possible or not, for example combining the deformation obtained from solidDisplacementFoam with another flow solver so that they are both ran simultaneously to see how the fluid pressures deform the body?
Would it require a large amount of work to implement? |
April 17, 2014, 08:23 |
Fluid structure interaction (FSI)
Fabian Roesler
Rep Power: 18 |
Hi
yes it is possible. What you are searching for is called "Fluid structure interaction (FSI)". However I never used the solvers and I think they are only implemented in the extend version. http://www.cfd-online.com/Forums/ope...-openfoam.html http://openfoam-extend.sourceforge.n...re_Interaction Hope this helps. Cheers Fabian |
April 17, 2014, 15:43 |
Rep Power: 12 |
Thank your reply. From what I have read the FSI requires an FEA package to do the structural analysis component of the simulation, I have also seen a couple of posts on this forum mentioning that OpenFOAM supports this and has it's own FEA simulation capibilities. Is this true? If so, are you aware of any documentation that is available for this?
Thanks. |
April 24, 2014, 03:39 |
Fabian Roesler
Rep Power: 18 |
I don't know if this is what you are searching for but OpenFOAM has several solvers for stress Analysis. They still use the FV-Method but can calculate linear-elastic, small-strain deformation of a solid. Here the information for solidDisplacementFoam: Transient segregated finite-volume solver of linear-elastic, small-strain deformation of a solid body, with optional thermal diffusion and thermal stresses. Simple linear elasticity structural analysis code. Solves for the displacement vector field D, also generating the stress tensor field sigma. Cheers Fabian |
cfd, combined solvers, stress analysis |
Shear Stress Calculation in the flow. | auburnuser | FLOW-3D | 11 | May 12, 2018 13:49 |
Contour of wall shear stress (average in the flow time) | pedroxramos | FLUENT | 6 | March 12, 2014 12:02 |
Shear stress fluctuations by turbulent flow | Meegao | FLUENT | 0 | October 11, 2012 05:54 |
Testing of OpenFOAM 1.4alpha Commenced | OpenFOAM discussion board administrator | OpenFOAM Announcements from ESI-OpenCFD | 0 | January 16, 2007 09:41 |
How to get shear stress all over the flow domain | lingo | FLUENT | 2 | November 3, 2003 21:16 |
