How can I add temperature equation in interfoam
Like Tree2Likes
  • 1 Post By seju
  • 1 Post By ahmmedshakil
Old   December 25, 2013, 09:38
Default How can I add temperature equation in interfoam
sajad
seju is on a distinguished road
Dear foamer, how can I add temperature equation in interfoam? I wanna use this for 2 phase flow.
do you have any references in this field?
best regards
chymalaia likes this.
seju is offline   Reply With Quote
Old   December 25, 2013, 12:22
sur4j is on a distinguished road
Hi Seju,
I am a beginner with OpenFOAM and used the following as a reference for adding temperature to existing solvers:
http://openfoamwiki.net/index.php/Ho...ure_to_icoFoam
It may help you with your simulation.
sur4j is offline   Reply With Quote
Old   December 26, 2013, 16:11
sajad
Originally Posted by sur4j View Post
Hi Seju,
hi sur4j. thanks for reply
add energy eq. to interfoam is diffterent with icoFoam.
best regards
sajad
Old   December 27, 2013, 07:15
shinji nakagawa
snak is on a distinguished road
Hi Seju,
compressibleInterFoam in OpenFOAM2.2.2 handles energy eq.
Description from source code...
24 Application
25 compressibleInterFoam
26
27 Description
28 Solver for 2 compressible, non-isothermal immiscible fluids using a VOF
29 (volume of fluid) phase-fraction based interface capturing approach.
30
31 The momentum and other fluid properties are of the "mixture" and a single
32 momentum equation is solved.
33
34 Turbulence modelling is generic, i.e. laminar, RAS or LES may be selected.
snak is offline   Reply With Quote
Old   December 27, 2013, 10:03
sajad
Originally Posted by snak View Post
Hi Seju,
24 Application
26
27 Description
30
33
hi snak,
thanks for reply
my case is not compressible.
can I use this?
best regards
sajad
Old   January 13, 2014, 08:40
Mahdi
Mahdi2010 is on a distinguished road
Although your case is not compressible, you may get the idea how to
implement energy equation by over-looking at the solver
Mahdi2010 is offline   Reply With Quote
Old   January 13, 2014, 10:30
sajad
thanks mehdi. Im trying to do it.
Old   February 11, 2014, 09:51
Mahdi
Have you got any progress in this implementation?
Old   February 11, 2014, 13:11
sajad
hi Mehdi,
Im so sorry.
I cant to do it.
Old   February 27, 2014, 00:46
Default add temperature equation in interfoam
Mohammad Shakil Ahmmed
ahmmedshakil is on a distinguished road
I guess this will help you.
interTempFoam is the solver and incompressibleTwoPhaseThermalMixture is the library file. Just compile the solver and the library file... thats it!!!!
cheers
#shakil
File Type: gz incompressibleTwoPhaseThermalMixture.tar.gz (2.3 KB, 246 views)
ahmmedshakil is offline   Reply With Quote
Old   February 27, 2014, 00:56
Also, you can have a look at the thread: http://www.cfd-online.com/Forums/ope...interfoam.html
cheers,
#shakil
Old   April 23, 2014, 04:09
sajad
cheers,
#shakil
hi Mohammad,thanks for reply. I cant compile the lib. can you help me?
best regards. Sajad
Old   April 23, 2014, 04:50
What type of problem you are facing ?(did you try with wmake libso ?)
Old   April 24, 2014, 00:12
sajad
did you compile that whit wmake libso?
when I type wmake libso I see a error and I ca'nt compile that.
best regards
Sajad
Old   April 24, 2014, 02:49
Default please try with that
  #15
Sorry, I got the problem. It's missing the linking of the library. Right now I'm extremely busy (probably I will fixed it later). Please try with the Qingming's file (Qingming Liu: Impementation of a myinterFoamDiabatic solver with OpenFOAM Slides Report Code Case)
in http://www.tfd.chalmers.se/~hani/kurser/OS_CFD_2011/ . It has a good explanation and it must work I guess.
Cheers,
shakil
hwangpo likes this.
Old   April 24, 2014, 07:30
sajad
Cheers,
shakil
dear shakil
thank you so much for reply.
in this link I can't found whats my problem.
I know you are busy but I'm waiting for revise this file in any time because I need this file.
best regards.
Sajad
Old   April 30, 2014, 09:38
sajad
Cheers,
shakil
Hi Shakil
did you try compile this lib and solver?
best regards
Sajad
The unit of thermal conductivity when adding temperature equation to icoFoam? mxylondon OpenFOAM 2 February 26, 2013 05:26
error message cuteapathy CFX 14 March 20, 2012 06:45
How to add correcting pressure equation in SIMPLE of MRFSimpleFOAM? renyun0511 OpenFOAM Programming & Development 0 November 4, 2010 01:38
Transport Equation for temperature variance ameya OpenFOAM Running, Solving & CFD 0 December 5, 2008 01:16
how to active temperature equation james FLUENT 0 June 19, 2006 03:54
