May 22, 2014, 07:46 |
Doubt in GAMMA scheme
Dear ALL,
In gamma scheme, the gamma coefficient is multiplied with "2" where gamma coefficient varies from 0.1 to 0.5. Whereas in OpenFOAM, I am finding it difficult to understand why the gamma coefficient is divided by "2". Refer code below for OpenFOAM: Code:
k_ = max (k_/2.0, SMALL) |
January 16, 2015, 12:27 |
Armin
Rep Power: 19 |
Not the newest thread, I know. But, an OpenFOAM developer (i.e. Henry Weller) gave some clarifications on this issue:
http://www.openfoam.org/mantisbt/view.php?id=1491#c3545 Hope this is of help! |
January 16, 2015, 12:32 |
Armin
Rep Power: 19 |
And I found another reference, where Hrvoje Jasak states basically the same:
http://www.cfd-online.com/Forums/ope...tml#post189665 Well, this inconsistency between the implementation and the original paper apparently leads every now and then to some confusion. |
January 17, 2015, 03:12 |
Hrvoje Jasak
Rep Power: 33 |
Actually, I changed it on purpose, after publishing the paper.
The natural range for k (see paper) is between 0 and 0.5. People were using the scheme with any number. The clever ones used the 0-1 range andwe ven got attempts to use 10! Therefore, I have re-scaled the factor and bound it to 0-1. In practical simulations, you will not be able to tell the difference. Hrv
Hrvoje Jasak Providing commercial FOAM/OpenFOAM and CFD Consulting: http://wikki.co.uk |
Why RNGkepsilon model gives floating error | shipman | OpenFOAM Running, Solving & CFD | 3 | September 7, 2013 08:00 |
Question about gamma intgerpolation scheme | titio | OpenFOAM Running, Solving & CFD | 0 | July 26, 2010 10:22 |
Differences between serial and parallel runs | carsten | OpenFOAM Bugs | 11 | September 12, 2008 11:16 |
Fundamental problem with Gamma scheme | dominik_christ | OpenFOAM Running, Solving & CFD | 3 | August 29, 2008 08:24 |
?to implement gamma differencing scheme | Gonski | Main CFD Forum | 15 | January 28, 2007 17:00 |
