Fix velocity value
Hello to the OpenFOAM community.
I'm trying to develop a code to simulate wind turbine without using dynamic mesh. In my domain i haven't the mesh of the turbine, i use a cube mesh i calculate the forces and applying that in the right point. I need to fix the velocity value in some point of the domain. In this point i want to fix the velocity without solving the U equation and i'm not sure that it 's possibile without drawing the geometry in the mesh. How can i set the value of the velocity? Thanks, :) |
Did you find a solution/workaround for this? If so, could you please share it?
Hi Mike,
Please have a look here, lines 18 to 61: https://github.com/vincentcasseau/hy...vEqnInviscid.H Once you've created your fvMatrix, you can use: Code:
my_fvMatrix.setValues(removedCellsFromMatrix, valuesToImpose); where the arguments are defined as follows: Code:
DynamicList<label> removedCellsFromMatrix; Thanks, Vincent |
