Find intersection between surface and mesh
Old   May 28, 2014, 09:31
Default Find intersection between surface and mesh
mike
mike_ is on a distinguished road
I'm trying to write a personal solver based on PISO.
I have to generate a cylinder and then find the intersection between this cylinder and my mesh.
The mesh is a cube with only cube element.
I want to save this intersection point in an dynamicList and after in this point i want to setup the velocity vector.
Can you help me?
Thanks very much.
mike_ is offline   Reply With Quote
intersection surface mesh
[ICEM] surface mesh merging problem everest ANSYS Meshing & Geometry 44 April 14, 2016 06:41
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 09:38
Cluster ID's not contiguous in compute-nodes domain. ??? Shogan FLUENT 1 May 28, 2014 15:03
[snappyHexMesh] Layers don't fully surround surface EVBUCF OpenFOAM Meshing & Mesh Conversion 14 August 20, 2012 04:31
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 21:11
