very simple problem with interFoam
Like Tree1Likes
  • 1 Post By momentum-analysis
Old   June 10, 2014, 02:13
Default very simple problem with interFoam
sajad
seju is on a distinguished road
dear foamer
I have very simple problem with interFoam:
I wanna saw the surface tension true implemented in interFoam. I used a square without gravity and I must saw square change into circle and steady. I run my case after that square change to circle but droplet start move in domain and has a unsteady regime and stream line is wrong. I change boundary conditions and mesh. answer be better but still answer is wrong and just amplitude move is decrease.
I'm used openFoam 2.2.1 and ubuntu 12.04
do you have any idea about my problem?
best regards
Sajad
seju is offline   Reply With Quote
Old   June 10, 2014, 03:14
ngj
Niels Gjoel Jacobsen
ngj will become famous soon enoughngj will become famous soon enough
Hi Sajad,
Yes, it is because of the generation of spurious current because of numerical inaccuracies in the surface treatment.
You will find a huge number of threads on this forum and scientific publications on this matter.
Kind regards,
Niels
P.S. This is not a "Programmering and development" question, so proper choice of subforum will help you in the future.
Please note that I do not use the Friend-feature, so do not be offended, if I do not accept a request.
ngj is offline   Reply With Quote
Old   August 9, 2014, 22:19
santiagomarquezd's Avatar
Santiago Marquez Damian
santiagomarquezd will become famous soon enough
Hi, the main problem is the curvature calculation.
Regards.
Santiago MÁRQUEZ DAMIÁN, Ph.D.
Research Scientist
Research Center for Computational Methods (CIMEC) - CONICET/UNL
Tel: 54-342-4511594 Int. 7032
Colectora Ruta Nac. 168 / Paraje El Pozo
(3000) Santa Fe - Argentina.
http://www.cimec.org.ar
santiagomarquezd is offline   Reply With Quote
Old   August 10, 2014, 00:37
sajad
Regards.
thanks my freinds for reply.
do you know how can I solve this problem? and do you have any idea or suggestion for solved this problem?
best regards
Sajad
Old   August 13, 2014, 12:36
Simon
momentum-analysis is on a distinguished road
Hi Sajad,
As others have said there is a lot of prior work looking into these numerical effects. I've found the following very useful as a reference when using interFoam
http://m.iopscience.iop.org/1749-469...014016/article
You might find the time-step limits helpful in your problem, although they can be restrictive in terms of solve time - I would suggest starting with them to see if they help and then backing off to find a suitable compromise for your model.
ngj likes this.
momentum-analysis is offline   Reply With Quote
[Technical] General meshing-question for simple (thermal) problem suitup OpenFOAM Meshing & Mesh Conversion 2 July 26, 2012 19:45
Simple Impinging Fountain problem MarkK CFX 4 February 5, 2011 05:30
Simple melting problem wawa FLUENT 0 January 28, 2011 12:19
Simple Meshing Problem with Gambit Mario FLUENT 4 April 18, 2003 09:52
? Simple CFD problem Davy Main CFD Forum 0 August 21, 1998 06:19
