Robin boundary condition for velocity
Old   July 2, 2014, 00:41
Default Robin boundary condition for velocity
Vishal Nandigana
nandiganavishal is on a distinguished road
Hello Foamers,
I am trying to solve a Laminar flow problem inside an axisymmetric cylindrical geometry with slip, where the slip length is specified by the user.
For this, I am trying to implement, the following boundary condition for velocity at the wall of a cylindrical geometry
dUz/dn = Uz/Ls
where Ls: Slip velocity
n = normal direction (radial direction in this case)
Uz = axial velocity
To implement this I was trying to write a FVPatch. Attached please find the codes for the above boundary condition.
The code compiled without any errors, but when running the solver, I received the following error.
gradientInternalCoeffs cannot be called for a genericFvPatchField (actual type USlip)
on patch nanopore_upperwall of field U in file "/home/cmn/Documents/RA_works/CNT_collab/case_2_2D_system/CNT_slip/rim_charges_only_no_reservoir/CNT_solve/0/U"
You are probably trying to solve for a field with a generic boundary condition.
From function genericFvPatchField<Type>::gradientInternalCoeffs( ) const
in file fields/fvPatchFields/basic/generic/genericFvPatchField.C at line 782.
FOAM exiting
Can you let me know what is the source for this error.
Thanks
Best
Vishal
U.txt
UslipFvPatchScalarField.C
UslipFvPatchScalarField.H
nandiganavishal is offline   Reply With Quote
Old   August 16, 2014, 11:04
Retired Super Moderator
Bruno Santos
Greetings Vishal,
As far as I can understand, you already have gotten an answer for this on this post: http://www.cfd-online.com/Forums/ope...tml#post499941 - post #39 - in that it's best to derive or simply use the direction mixed BC.
Best regards,
Bruno
An error has occurred in cfx5solve: volo87 CFX 5 June 14, 2013 17:44
Low Mixing time Problem Mavier CFX 5 April 29, 2013 00:00
Velocity profile boundary condition Tuca FLOW-3D 1 April 23, 2013 12:02
asking for Boundary condition in FLUENT Destry FLUENT 0 July 27, 2010 00:55
External Radiation Boundary Condition for Grid Interface CFD XUE FLUENT 0 July 9, 2010 02:53
