Update pressure with temperature?
Old   April 5, 2013, 03:36
Default Update pressure with temperature?
Cameron
c_dowd is on a distinguished road
I've got an incompressible combustion model, which updates temperature based on a combustion model. Now I would like to have this temperature affect the pressure field, but I can't for the life of me think how to do this. I realise it's something to do with the thermophysical model and the thermo->correct line, however my pressure still stays constant.
c_dowd is offline   Reply With Quote
Old   April 5, 2013, 04:28
Cameron
Okay I am fairly certain the thermo.correct() line is the one responsible for updating the pressure with temperature, and the reason it's not working is because I'm using a psi type thermophysical model and my psi values aren't being update. I'm using a psi thermophysical model in order to use the built in combustion models, is there some way to update my psi values during the run? I tried psi = thermo.psi(), but this gave me errors.
Old   July 10, 2014, 12:24
Default Incompressible combustion model
James
ni-openfoam-user is on a distinguished road
Dear Cameron,
I am currently working on modifying the "reactingFoam" solver from compressible to incompressible".
I have started by changing the Make/options file.
However I will also need to include an incompressible combustion model (to replace the current compressible combustion models available)
If possible could you post your incompressible combustion model?
I ultimately wish to simulate a high pressure hydrogen release (3 mm diameter at about 1000 m/s).
My plan is to use reactingFoam (switching off chemistry and reactions). I plan to modify the reactingFoam solver into an incompressible solver and then further modify it to run in steady state.
I would appreciate any comments or advice regarding this approach?
Kind regards,
James
ni-openfoam-user is offline   Reply With Quote
combustion, pressure, temperature
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
Density of fluid with respect to temperature and pressure akash_max CFX 4 November 6, 2011 09:00
Pressure and Temperature UDF for Cell Zone elixer2104 FLUENT 0 February 24, 2011 11:54
Does star cd takes reference pressure? monica Siemens 1 April 19, 2007 11:26
Neumann pressure BC and velocity field Antech Main CFD Forum 0 April 25, 2006 02:15
