boundary conditions effect on Matrix coefficients
Old   October 20, 2015, 04:28
Default boundary conditions effect on Matrix coefficients
martel is on a distinguished road
Hi all,
I am trying to understand how openfoam generates the matrices for the differential operators.
I have programmed a simple example for the laplacian operator:
// Define a matrix that contains the coefficients of the Laplacian
    fvScalarMatrix TEqnLaplaciano
	   fvm::laplacian(DT, T)
// Extract source term, matrix diagonal, upper and lower nonzero elements and their indices
    scalarField& source_  = TEqnLaplaciano.source();
    scalarField& lower_   = TEqnLaplaciano.lower();
    scalarField& upper_   = TEqnLaplaciano.upper();
    scalarField& diag_    = TEqnLaplaciano.diag();
    const unallocLabelList& l_ = TEqnLaplaciano.lduAddr().lowerAddr();
    const unallocLabelList& u_ = TEqnLaplaciano.lduAddr().upperAddr();
    Info<< "\n diagvalues:  \n " << diag_  << endl;
    Info<< "\n lowervalues: \n " << lower_ << endl;
    Info<< "\n lowerAddr:   \n " << l_     << endl;
    Info<< "\n Uppervalues: \n " << upper_ << endl;
    Info<< "\n UpperAddr:   \n " << u_     << endl;
    Info<< "\n sourcevalues:  \n " << source_  << endl;
And it gives:
* Matrix Diagonal terms
* Matrix out of diagonal terms
* Indices of the out of diagonal terms
* source terms (right hand side of the linear system) (zero in my example)
But the effect of the boundary conditions is not yet included in the matrix and source term that I get.
My question is:
How can I get the contribution (coefficients and indices) of the Boundary Conditions to the matrix coefficients (diag and out-of-diag) and to the source term?
Thanks in advance for your help.
--CME
martel is offline   Reply With Quote
Old   February 24, 2016, 17:16
gigilentini8 is on a distinguished road
same question here. any news on this?
gigilentini8 is offline   Reply With Quote
Old   March 1, 2016, 10:46
Hi gigilentin8i,
Not much on this unfortunaltely:
I have use these two extra lines to get the information from the boundary conditions:
 Info <<"\n  TEqnLaplaciano.boundaryCoeffs()     \n " <<       TEqnLaplaciano.boundaryCoeffs() << endl;
    Info <<"\n  TEqnLaplaciano.internalCoeffs()     \n " <<       TEqnLaplaciano.internalCoeffs() << endl;
But I have realized that OpenFoam does not construct the complete matrix of the laplacian because the non-orhogonal contributions to the operator are ALWAYS computed explicitely. So now I am trying to export the mesh coefficients to build the matrices myself in MATLAB.
--Carlos
Old   March 1, 2016, 19:47
Thanks Carlos,
this explains why I am getting incorrect results for the eigenvalues/functions of the laplacian when the mesh is non cartesian.
does this mean that the additional non-orthogonal contribution are in TEqn.source()? If this is the case I could just try to put them back in the matrix.
or how about using an uncorrected or fourth scheme?
I was able to add the boundary condition contribution to the matrix with this code
    forAll(TEqn.internalCoeffs(), patchI)
        const label*  fPtr = TEqn.lduAddr().patchAddr(patchI).begin();
        Field<double> intF(TEqn.internalCoeffs()[patchI].component(0));
        forAll(TEqn.lduAddr().patchAddr(patchI), faceI)
              label fCell = fPtr[faceI];
              diag(fCell) -= intF[faceI];
Originally Posted by martel View Post
Hi gigilentin8i,
--Carlos
Setting the height of the stream in the free channel kevinmccartin CFX 12 October 13, 2022 21:43
CGNS Boundary conditions using SU2 denzell SU2 3 July 9, 2018 05:58
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 07:00
How the boundary conditions are disposed into the matrix coefficient? mxylondon OpenFOAM 1 March 1, 2013 16:03
Matrix coefficients from boundary conditions how tehache OpenFOAM Running, Solving & CFD 10 October 16, 2011 18:26
