Multiple volScalarFields using List<volScalarField>
Like Tree19Likes
  • 15 Post By mkraposhin
  • 1 Post By vbchris
  • 1 Post By mkraposhin
  • 1 Post By l_r_mcglashan
  • 1 Post By atoof
Old   February 15, 2013, 17:47
Default Multiple volScalarFields using List<volScalarField>
Chris L
vbchris is on a distinguished road
I would like to initialize a list of volScalarFields. This will be used for the calculation of concentrations of multiple species.
I used the following code to initialize the volScalarFields in createFields.h
I also thought about using ptrlist<volScalarField>.
What I thought the code would do is create a list size 3 (to be size n) of volScalarField objects called T. T[1] was used in the solver code by using the intermediate Ti.
    volScalarField Temp_field
        IOobject
            "T",
            runTime.timeName(),
            mesh,
            IOobject::MUST_READ,
            IOobject::AUTO_WRITE
        mesh
    List<volScalarField> T;
    T.setSize(3);
    for (label i=0; i<3; i++)
        T[i] = Temp_field;
And implemented it into the scalarTransportFoam solver with
    while (simple.loop())
        Info<< "Time = " << runTime.timeName() << nl << endl;
        while (simple.correctNonOrthogonal())
        volScalarField& Ti = T[1];
            solve
                fvm::ddt(Ti) ///HERE
              + fvm::div(phi, Ti) ///HERE
              - fvm::laplacian(DT, Ti) ///HERE
However, the code won't compile. From the debug it looks like I'm not passing a volScalarField to the solve() function. Here is the debug output on OpenFoam 2.1.1:
Making dependency list for source file myScalarTransportFoam.C
SOURCE=myScalarTransportFoam.C ;  g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-100 -I/opt/openfoam211/src/finiteVolume/lnInclude -I/opt/openfoam211/src/lnInclude -IlnInclude -I. -I/opt/openfoam211/src/OpenFOAM/lnInclude -I/opt/openfoam211/src/OSspecific/POSIX/lnInclude   -fPIC -c $SOURCE -o Make/linux64GccDPOpt/myScalarTransportFoam.o
myScalarTransportFoam.C: In function ‘int main(int, char**)’:
myScalarTransportFoam.C:67:27: error: no matching function for call to ‘ddt(Foam::List<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> >&)’
myScalarTransportFoam.C:67:27: note: candidates are:
/opt/openfoam211/src/finiteVolume/lnInclude/fvmDdt.C:45:1: note: template<class Type> Foam::tmp<Foam::fvMatrix<Type> > Foam::fvm::ddt(const Foam::GeometricField<Type, Foam::fvPatchField, Foam::volMesh>&)
/opt/openfoam211/src/finiteVolume/lnInclude/fvmDdt.C:60:1: note: template<class Type> Foam::tmp<Foam::fvMatrix<Type> > Foam::fvm::ddt(const Foam::one&, const Foam::GeometricField<Type, Foam::fvPatchField, Foam::volMesh>&)
/opt/openfoam211/src/finiteVolume/lnInclude/fvmDdt.C:72:1: note: template<class Type> Foam::tmp<Foam::fvMatrix<Type> > Foam::fvm::ddt(const dimensionedScalar&, const Foam::GeometricField<Type, Foam::fvPatchField, Foam::volMesh>&)
/opt/openfoam211/src/finiteVolume/lnInclude/fvmDdt.C:88:1: note: template<class Type> Foam::tmp<Foam::fvMatrix<Type> > Foam::fvm::ddt(const volScalarField&, const Foam::GeometricField<Type, Foam::fvPatchField, Foam::volMesh>&)
myScalarTransportFoam.C:68:32: error: no matching function for call to ‘div(Foam::surfaceScalarField&, Foam::List<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> >&)’
myScalarTransportFoam.C:68:32: note: candidates are:
/opt/openfoam211/src/finiteVolume/lnInclude/fvmDiv.C:45:1: note: template<class Type> Foam::tmp<Foam::fvMatrix<Type> > Foam::fvm::div(const surfaceScalarField&, const Foam::GeometricField<Type, Foam::fvPatchField, Foam::volMesh>&, const Foam::word&)
/opt/openfoam211/src/finiteVolume/lnInclude/fvmDiv.C:62:1: note: template<class Type> Foam::tmp<Foam::fvMatrix<Type> > Foam::fvm::div(const Foam::tmp<Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> >&, const Foam::GeometricField<Type, Foam::fvPatchField, Foam::volMesh>&, const Foam::word&)
/opt/openfoam211/src/finiteVolume/lnInclude/fvmDiv.C:77:1: note: template<class Type> Foam::tmp<Foam::fvMatrix<Type> > Foam::fvm::div(const surfaceScalarField&, const Foam::GeometricField<Type, Foam::fvPatchField, Foam::volMesh>&)
/opt/openfoam211/src/finiteVolume/lnInclude/fvmDiv.C:88:1: note: template<class Type> Foam::tmp<Foam::fvMatrix<Type> > Foam::fvm::div(const Foam::tmp<Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> >&, const Foam::GeometricField<Type, Foam::fvPatchField, Foam::volMesh>&)
myScalarTransportFoam.C:69:37: error: no matching function for call to ‘laplacian(Foam::dimensionedScalar&, Foam::List<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> >&)’
myScalarTransportFoam.C:69:37: note: candidates are:
/opt/openfoam211/src/finiteVolume/lnInclude/fvmLaplacian.C:45:1: note: template<class Type> Foam::tmp<Foam::fvMatrix<Type> > Foam::fvm::laplacian(const Foam::GeometricField<Type, Foam::fvPatchField, Foam::volMesh>&, const Foam::word&)
/opt/openfoam211/src/finiteVolume/lnInclude/fvmLaplacian.C:70:1: note: template<class Type> Foam::tmp<Foam::fvMatrix<Type> > Foam::fvm::laplacian(const Foam::GeometricField<Type, Foam::fvPatchField, Foam::volMesh>&)
/opt/openfoam211/src/finiteVolume/lnInclude/fvmLaplacian.C:99:1: note: template<class Type> Foam::tmp<Foam::fvMatrix<Type> > Foam::fvm::laplacian(const Foam::zero&, const Foam::GeometricField<Type, Foam::fvPatchField, Foam::volMesh>&, const Foam::word&)
/opt/openfoam211/src/finiteVolume/lnInclude/fvmLaplacian.C:115:1: note: template<class Type> Foam::tmp<Foam::fvMatrix<Type> > Foam::fvm::laplacian(const Foam::zero&, const Foam::GeometricField<Type, Foam::fvPatchField, Foam::volMesh>&)
/opt/openfoam211/src/finiteVolume/lnInclude/fvmLaplacian.C:130:1: note: template<class Type> Foam::tmp<Foam::fvMatrix<Type> > Foam::fvm::laplacian(const Foam::one&, const Foam::GeometricField<Type, Foam::fvPatchField, Foam::volMesh>&, const Foam::word&)
/opt/openfoam211/src/finiteVolume/lnInclude/fvmLaplacian.C:143:1: note: template<class Type> Foam::tmp<Foam::fvMatrix<Type> > Foam::fvm::laplacian(const Foam::one&, const Foam::GeometricField<Type, Foam::fvPatchField, Foam::volMesh>&)
/opt/openfoam211/src/finiteVolume/lnInclude/fvmLaplacian.C:155:1: note: template<class Type, class GType> Foam::tmp<Foam::fvMatrix<Type> > Foam::fvm::laplacian(const Foam::dimensioned<Type2>&, const Foam::GeometricField<Type, Foam::fvPatchField, Foam::volMesh>&, const Foam::word&)
/opt/openfoam211/src/finiteVolume/lnInclude/fvmLaplacian.C:181:1: note: template<class Type, class GType> Foam::tmp<Foam::fvMatrix<Type> > Foam::fvm::laplacian(const Foam::dimensioned<Type2>&, const Foam::GeometricField<Type, Foam::fvPatchField, Foam::volMesh>&)
/opt/openfoam211/src/finiteVolume/lnInclude/fvmLaplacian.C:208:1: note: template<class Type, class GType> Foam::tmp<Foam::fvMatrix<Type> > Foam::fvm::laplacian(const Foam::GeometricField<GType, Foam::fvPatchField, Foam::volMesh>&, const Foam::GeometricField<Type, Foam::fvPatchField, Foam::volMesh>&, const Foam::word&)
/opt/openfoam211/src/finiteVolume/lnInclude/fvmLaplacian.C:240:1: note: template<class Type, class GType> Foam::tmp<Foam::fvMatrix<Type> > Foam::fvm::laplacian(const Foam::GeometricField<GType, Foam::fvPatchField, Foam::volMesh>&, const Foam::GeometricField<Type, Foam::fvPatchField, Foam::volMesh>&)
/opt/openfoam211/src/finiteVolume/lnInclude/fvmLaplacian.C:225:1: note: template<class Type, class GType> Foam::tmp<Foam::fvMatrix<Type> > Foam::fvm::laplacian(const Foam::tmp<Foam::GeometricField<GType, Foam::fvPatchField, Foam::volMesh> >&, const Foam::GeometricField<Type, Foam::fvPatchField, Foam::volMesh>&, const Foam::word&)
/opt/openfoam211/src/finiteVolume/lnInclude/fvmLaplacian.C:257:1: note: template<class Type, class GType> Foam::tmp<Foam::fvMatrix<Type> > Foam::fvm::laplacian(const Foam::tmp<Foam::GeometricField<GType, Foam::fvPatchField, Foam::volMesh> >&, const Foam::GeometricField<Type, Foam::fvPatchField, Foam::volMesh>&)
/opt/openfoam211/src/finiteVolume/lnInclude/fvmLaplacian.C:273:1: note: template<class Type, class GType> Foam::tmp<Foam::fvMatrix<Type> > Foam::fvm::laplacian(const Foam::GeometricField<GType, Foam::fvsPatchField, Foam::surfaceMesh>&, const Foam::GeometricField<Type, Foam::fvPatchField, Foam::volMesh>&, const Foam::word&)
/opt/openfoam211/src/finiteVolume/lnInclude/fvmLaplacian.C:290:1: note: template<class Type, class GType> Foam::tmp<Foam::fvMatrix<Type> > Foam::fvm::laplacian(const Foam::tmp<Foam::GeometricField<GType, Foam::fvsPatchField, Foam::surfaceMesh> >&, const Foam::GeometricField<Type, Foam::fvPatchField, Foam::volMesh>&, const Foam::word&)
/opt/openfoam211/src/finiteVolume/lnInclude/fvmLaplacian.C:305:1: note: template<class Type, class GType> Foam::tmp<Foam::fvMatrix<Type> > Foam::fvm::laplacian(const Foam::GeometricField<GType, Foam::fvsPatchField, Foam::surfaceMesh>&, const Foam::GeometricField<Type, Foam::fvPatchField, Foam::volMesh>&)
/opt/openfoam211/src/finiteVolume/lnInclude/fvmLaplacian.C:322:1: note: template<class Type, class GType> Foam::tmp<Foam::fvMatrix<Type> > Foam::fvm::laplacian(const Foam::tmp<Foam::GeometricField<GType, Foam::fvsPatchField, Foam::surfaceMesh> >&, const Foam::GeometricField<Type, Foam::fvPatchField, Foam::volMesh>&)
myScalarTransportFoam.C:80:68: error: ‘class Foam::List<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> >’ has no member named ‘boundaryField’
In file included from /opt/openfoam211/src/OpenFOAM/lnInclude/List.H:259:0,
                 from /opt/openfoam211/src/OpenFOAM/lnInclude/labelList.H:48,
                 from /opt/openfoam211/src/OpenFOAM/lnInclude/UPstream.H:43,
                 from /opt/openfoam211/src/OpenFOAM/lnInclude/Pstream.H:42,
                 from /opt/openfoam211/src/OpenFOAM/lnInclude/parRun.H:35,
                 from /opt/openfoam211/src/finiteVolume/lnInclude/fvCFD.H:4,
                 from myScalarTransportFoam.C:32:
/opt/openfoam211/src/OpenFOAM/lnInclude/List.C: In member function ‘void Foam::List<T>::setSize(Foam::label) [with T = Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>, Foam::label = int]’:
createFields.H:21:16:   instantiated from here
/opt/openfoam211/src/OpenFOAM/lnInclude/List.C:331:41: error: no matching function for call to ‘Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::GeometricField()’
/opt/openfoam211/src/OpenFOAM/lnInclude/List.C:331:41: note: candidates are:
/opt/openfoam211/src/OpenFOAM/lnInclude/GeometricField.C:625:1: note: Foam::GeometricField<Type, PatchField, GeoMesh>::GeometricField(const Foam::IOobject&, const Foam::GeometricField<Type, PatchField, GeoMesh>&, const wordList&, const wordList&) [with Type = double, PatchField = Foam::fvPatchField, GeoMesh = Foam::volMesh, Foam::wordList = Foam::List<Foam::word>]
/opt/openfoam211/src/OpenFOAM/lnInclude/GeometricField.C:625:1: note:   candidate expects 4 arguments, 0 provided
/opt/openfoam211/src/OpenFOAM/lnInclude/GeometricField.C:590:1: note: Foam::GeometricField<Type, PatchField, GeoMesh>::GeometricField(const Foam::IOobject&, const Foam::GeometricField<Type, PatchField, GeoMesh>&, const Foam::word&) [with Type = double, PatchField = Foam::fvPatchField, GeoMesh = Foam::volMesh]
/opt/openfoam211/src/OpenFOAM/lnInclude/GeometricField.C:590:1: note:   candidate expects 3 arguments, 0 provided
/opt/openfoam211/src/OpenFOAM/lnInclude/GeometricField.C:560:1: note: Foam::GeometricField<Type, PatchField, GeoMesh>::GeometricField(const Foam::word&, const Foam::tmp<Foam::GeometricField<Type, PatchField, GeoMesh> >&) [with Type = double, PatchField = Foam::fvPatchField, GeoMesh = Foam::volMesh]
/opt/openfoam211/src/OpenFOAM/lnInclude/GeometricField.C:560:1: note:   candidate expects 2 arguments, 0 provided
/opt/openfoam211/src/OpenFOAM/lnInclude/GeometricField.C:527:1: note: Foam::GeometricField<Type, PatchField, GeoMesh>::GeometricField(const Foam::word&, const Foam::GeometricField<Type, PatchField, GeoMesh>&) [with Type = double, PatchField = Foam::fvPatchField, GeoMesh = Foam::volMesh]
/opt/openfoam211/src/OpenFOAM/lnInclude/GeometricField.C:527:1: note:   candidate expects 2 arguments, 0 provided
/opt/openfoam211/src/OpenFOAM/lnInclude/GeometricField.C:495:1: note: Foam::GeometricField<Type, PatchField, GeoMesh>::GeometricField(const Foam::IOobject&, const Foam::GeometricField<Type, PatchField, GeoMesh>&) [with Type = double, PatchField = Foam::fvPatchField, GeoMesh = Foam::volMesh]
/opt/openfoam211/src/OpenFOAM/lnInclude/GeometricField.C:495:1: note:   candidate expects 2 arguments, 0 provided
/opt/openfoam211/src/OpenFOAM/lnInclude/GeometricField.C:464:1: note: Foam::GeometricField<Type, PatchField, GeoMesh>::GeometricField(const Foam::tmp<Foam::GeometricField<Type, PatchField, GeoMesh> >&) [with Type = double, PatchField = Foam::fvPatchField, GeoMesh = Foam::volMesh]
/opt/openfoam211/src/OpenFOAM/lnInclude/GeometricField.C:464:1: note:   candidate expects 1 argument, 0 provided
/opt/openfoam211/src/OpenFOAM/lnInclude/GeometricField.C:432:1: note: Foam::GeometricField<Type, PatchField, GeoMesh>::GeometricField(const Foam::GeometricField<Type, PatchField, GeoMesh>&) [with Type = double, PatchField = Foam::fvPatchField, GeoMesh = Foam::volMesh]
/opt/openfoam211/src/OpenFOAM/lnInclude/GeometricField.C:432:1: note:   candidate expects 1 argument, 0 provided
/opt/openfoam211/src/OpenFOAM/lnInclude/GeometricField.C:393:1: note: Foam::GeometricField<Type, PatchField, GeoMesh>::GeometricField(const Foam::IOobject&, const Mesh&, const Foam::dictionary&) [with Type = double, PatchField = Foam::fvPatchField, GeoMesh = Foam::volMesh, Foam::GeometricField<Type, PatchField, GeoMesh>::Mesh = Foam::fvMesh]
/opt/openfoam211/src/OpenFOAM/lnInclude/GeometricField.C:393:1: note:   candidate expects 3 arguments, 0 provided
/opt/openfoam211/src/OpenFOAM/lnInclude/GeometricField.C:353:1: note: Foam::GeometricField<Type, PatchField, GeoMesh>::GeometricField(const Foam::IOobject&, const Mesh&) [with Type = double, PatchField = Foam::fvPatchField, GeoMesh = Foam::volMesh, Foam::GeometricField<Type, PatchField, GeoMesh>::Mesh = Foam::fvMesh]
/opt/openfoam211/src/OpenFOAM/lnInclude/GeometricField.C:353:1: note:   candidate expects 2 arguments, 0 provided
/opt/openfoam211/src/OpenFOAM/lnInclude/GeometricField.C:326:1: note: Foam::GeometricField<Type, PatchField, GeoMesh>::GeometricField(const Foam::IOobject&, const Mesh&, const Foam::dimensionSet&, const Foam::Field<TypeR>&, const Foam::PtrList<PatchField<Type> >&) [with Type = double, PatchField = Foam::fvPatchField, GeoMesh = Foam::volMesh, Foam::GeometricField<Type, PatchField, GeoMesh>::Mesh = Foam::fvMesh]
/opt/openfoam211/src/OpenFOAM/lnInclude/GeometricField.C:326:1: note:   candidate expects 5 arguments, 0 provided
/opt/openfoam211/src/OpenFOAM/lnInclude/GeometricField.C:296:1: note: Foam::GeometricField<Type, PatchField, GeoMesh>::GeometricField(const Foam::IOobject&, const Mesh&, const Foam::dimensioned<Form>&, const wordList&, const wordList&) [with Type = double, PatchField = Foam::fvPatchField, GeoMesh = Foam::volMesh, Foam::GeometricField<Type, PatchField, GeoMesh>::Mesh = Foam::fvMesh, Foam::wordList = Foam::List<Foam::word>]
/opt/openfoam211/src/OpenFOAM/lnInclude/GeometricField.C:296:1: note:   candidate expects 5 arguments, 0 provided
/opt/openfoam211/src/OpenFOAM/lnInclude/GeometricField.C:267:1: note: Foam::GeometricField<Type, PatchField, GeoMesh>::GeometricField(const Foam::IOobject&, const Mesh&, const Foam::dimensioned<Form>&, const Foam::word&) [with Type = double, PatchField = Foam::fvPatchField, GeoMesh = Foam::volMesh, Foam::GeometricField<Type, PatchField, GeoMesh>::Mesh = Foam::fvMesh]
/opt/openfoam211/src/OpenFOAM/lnInclude/GeometricField.C:267:1: note:   candidate expects 4 arguments, 0 provided
/opt/openfoam211/src/OpenFOAM/lnInclude/GeometricField.C:239:1: note: Foam::GeometricField<Type, PatchField, GeoMesh>::GeometricField(const Foam::IOobject&, const Mesh&, const Foam::dimensionSet&, const wordList&, const wordList&) [with Type = double, PatchField = Foam::fvPatchField, GeoMesh = Foam::volMesh, Foam::GeometricField<Type, PatchField, GeoMesh>::Mesh = Foam::fvMesh, Foam::wordList = Foam::List<Foam::word>]
/opt/openfoam211/src/OpenFOAM/lnInclude/GeometricField.C:239:1: note:   candidate expects 5 arguments, 0 provided
/opt/openfoam211/src/OpenFOAM/lnInclude/GeometricField.C:209:1: note: Foam::GeometricField<Type, PatchField, GeoMesh>::GeometricField(const Foam::IOobject&, const Mesh&, const Foam::dimensionSet&, const Foam::word&) [with Type = double, PatchField = Foam::fvPatchField, GeoMesh = Foam::volMesh, Foam::GeometricField<Type, PatchField, GeoMesh>::Mesh = Foam::fvMesh]
/opt/openfoam211/src/OpenFOAM/lnInclude/GeometricField.C:209:1: note:   candidate expects 4 arguments, 0 provided
make: *** [Make/linux64GccDPOpt/myScalarTransportFoam.o] Error 1
Any assistance would be greatly appreciated!
vbchris is offline   Reply With Quote
Old   February 16, 2013, 12:54
mkraposhin's Avatar
Matvey Kraposhin
mkraposhin is on a distinguished road
Hello, You made some mistakes:
1) You declared array of volScalarField - but List<template A> of A-template needs default constructor for A class, which is forbidden for volScalarField (A == volScalarField)
2) In the init and solution loop You are using reference assignment - wall variables will reference only to "T" field
Solution - List of Pointers - List<autoPtr<volScalarField> >, i made easy example for laplacianFoam, You can use it to change Your own solver:
createFields.H:
    Info<< "Reading field T\n" << endl;
    label N = 2;
    List<autoPtr<volScalarField> > TiPtr (N);
    forAll (TiPtr, iField)
        word nameTi ("T" + name(iField));
        TiPtr[iField].reset
            new volScalarField
                IOobject
                    nameTi,
                    runTime.timeName(),
                    mesh,
                mesh
    volScalarField T
        IOobject
            "T",
            runTime.timeName(),
            mesh,
        mesh
    Info<< "Reading transportProperties\n" << endl;
    IOdictionary transportProperties
        IOobject
            "transportProperties",
            runTime.constant(),
            mesh,
            IOobject::MUST_READ_IF_MODIFIED,
            IOobject::NO_WRITE
    Info<< "Reading diffusivity DT\n" << endl;
    dimensionedScalar DT
        transportProperties.lookup("DT")
myLaplacianFoam.C
#include "fvCFD.H"
#include "simpleControl.H"
int main(int argc, char *argv[])
    #include "setRootCase.H"
    #include "createTime.H"
    #include "createMesh.H"
    #include "createFields.H"
    simpleControl simple(mesh);
    Info<< "\nCalculating temperature distribution\n" << endl;
            solve
                fvm::ddt(T) - fvm::laplacian(DT, T)
            forAll(TiPtr, iField)
                volScalarField& Ti = TiPtr[iField]();
                solve
                    fvm::ddt(Ti) - fvm::laplacian(DT,Ti)
        #include "write.H"
        Info<< "ExecutionTime = " << runTime.elapsedCpuTime() << " s"
            << "  ClockTime = " << runTime.elapsedClockTime() << " s"
            << nl << endl;
    Info<< "End\n" << endl;
    return 0;
And here you can find code example, tutorial you can take from flange example (don't forget to create field T0 and T1)
mkraposhin is offline   Reply With Quote
Old   February 16, 2013, 16:57
Chris L
Thanks,
I modified your solution a bit and used ptrlist<>.
Do you have any comments on this method?
Compiles fine, I will modify it later to read in from multiple files.
PtrList<volScalarField> PopBal(bin_count);
for(count = 0; count < bin_count; count++)
    PopBal.set
        count,
        new volScalarField
            IOobject
                "T",
                runTime.timeName(),
                mesh,
            mesh
charryzzz likes this.
Old   February 17, 2013, 05:24
mkraposhin's Avatar
Matvey Kraposhin
PtrList is the same as List<volScalarField* >, which holds pure (hardware) pointers,
List<autoPtr<volScalarField> > holds list of software pointers (autoPtr<>), which is safer, for me,
for different filenames, you can substitute string:
word nameTi ("fieldName" + name(fieldCounter))
Ramzy1990 likes this.
Old   February 18, 2013, 05:34
Laurence R. McGlashan
l_r_mcglashan will become famous soon enough
You cannot use copy or assignment on a List of autoPtr though.
Laurence R. McGlashan :: Website
l_r_mcglashan is offline   Reply With Quote
Old   June 5, 2013, 10:13
Default question about creating a list
Farah Yasmina
bubbleToes is on a distinguished road
I am writing here because it is one of the only threads where Lists are mentioned.
I want to create a List out of a class I made, ie. I want every object that I add or remove in my main program to be sorted out in a list in order to be able to apply the methods I have created on every single object.
To be more specific, my class is called "Vessels" and one of the methods I use calculates the value of blood flow in a given vessel.
My main program calculates pressure distribution and blood flow in my computational domain, and I want to be able to add as much arteries & veins as I like without having to calculate for everyone single one of them the corresponding blood flow.
I'm new to OF & C++ and would really appreciate your help. Thanks!
bubbleToes is offline   Reply With Quote
Old   September 14, 2014, 06:38
Hossein
atoof is on a distinguished road
Send a message via Yahoo to atoof
createFields.H:
    label N = 2;
        TiPtr[iField].reset
            new volScalarField
                IOobject
                    nameTi,
                    runTime.timeName(),
                    mesh,
                mesh
I used the following code in my new solver that based on reactingFoam OF2.1.x.
    forAll(spNames, specieI)
        word namemuIi ("muI" + name(specieI));
        muI.set
        specieI,
        new volScalarField
            IOobject
                namemuIi,
                runTime.timeName(),
                mesh,
                IOobject::NO_READ,
                IOobject::NO_WRITE
            dimensionedScalar("muI", dimensionSet(1, -1, -1, 0, 0, 0, 0), 2.6693E-05 * Foam::pow(composition.W(specieI) * T, 0.5)/ Foam::pow(sigmaI,2)/ om22)
Where
PtrList<volScalarField> muI(Y.size());
, T is a volScalarField with dimension of temperature, Y is the list of species value in the domain and sigmaI is a scalar. Indeed I'm going to generate n volScalarFields, where n in the number of species.
After compiling the solver, I encounter the following error:
error: no matching function for call to ‘Foam::dimensioned<double>::dimensioned(const char [7], const Foam::dimensionSet&, Foam::volScalarField&)’
/home/mohammad/OpenFOAM/OpenFOAM-2.1.x/src/OpenFOAM/lnInclude/dimensionedType.C:68:1: note:   no known conversion for argument 3 from ‘Foam::volScalarField {aka Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>}’ to ‘double’
In file included from /home/mohammad/OpenFOAM/OpenFOAM-2.1.x/src/OpenFOAM/lnInclude/dimensionedScalar.H:38:0,
How can I remove the error?
Regards,
Hossein
atoof is offline   Reply With Quote
how to set periodic boundary conditions Ganesh FLUENT 15 November 18, 2020 06:09
[ICEM] Multiple edges asal ANSYS Meshing & Geometry 2 March 22, 2013 10:10
OpenFOAM static build on Cray XT5 asaijo OpenFOAM Installation 9 April 6, 2011 12:21
Multiple domain/Multiple material problems... possible or not? Amiga500 OpenFOAM 1 April 14, 2010 15:32
Multiple reference frames? Moon Siemens 0 March 4, 2003 06:32
