October 30, 2014, 12:11 |
Arguments of implicit divergence-term
chubb87
Rep Power: 14 |
Hi all,
I need to implement an equation (which approximates the Jacobian in a Newton method) containing the following terms: Code:
fvm::ddt(rho) + 1/eps*(fvc::div(phi_old) - fvm::div(phi_old+eps*(phi-phi_old),rho) I already tried something like Code:
fvm::ddt(rho) + 1/eps*(fvc::div(phi_old) - fvm::div(phi_old/phi_rho+eps*(phiU-phi_old/phi_rho)),rho) Any ideas? Do I have to approximate the second divergence term? Thanks in advance. |
October 31, 2014, 07:19 |
Rep Power: 18 |
The variable which is solved for always appears in the second argument of the fvm operators.
You should maybe think about using the linearity of the divergence operator to separate the terms, and use an explicit divergence (fvc::div) for phi_old ? |
November 1, 2014, 08:33 |
chubb87
Rep Power: 14 |
Okay, that's what I tried as well. I was unsure if this is valid though, since this would lead to cancellation of most terms (even epsilon drops out!) and thus would not make sense.
If I use linearity but keep those terms the calculation might still be valid (I guess). It does not work as expected yet (density increases), but the problem may be somewhere else. |
[ANSYS Meshing] Help with element size | sandri_92 | ANSYS Meshing & Geometry | 14 | November 14, 2018 07:54 |
implicit - scalar product source term in momentum equation | vinch | OpenFOAM Running, Solving & CFD | 0 | October 28, 2014 14:57 |
Divergence problem | Smaras | FLUENT | 13 | February 21, 2013 05:03 |
How to install CGNS under windows xp? | lzgwhy | Main CFD Forum | 1 | January 11, 2011 18:44 |
CGNS lib and Fortran compiler | manaliac | Main CFD Forum | 2 | November 29, 2010 06:25 |
