What is the trigger of the function objects??
Dear foamer,
In any solver, one can add some function objects in the controlDict. They are triggered at the end of each solver timestep. In the solvers, I guess that the triggering line of code is "runTime.write()". Is that true? Is it possible to trigger a function object at a different location in the source code? For example, I want to extract the field average of a LES run just after the prediction loop of pimpleFoam (after UEqu.H). What kind of code can I add to trigger a funcObj call? Best, Marcel |
1 Attachment(s)
(Below I take v2.3.x as my version.)
As part of my internship, I duck into the lagrangian library for which I looked into both FunctionObjects and CloudFunctionObjects. Attached you'll find a qualitative UML diagram showing the calling sequence of methods. The top-left of the image is the execution of a FunctionObject. Tracing FunctionObjects, one may find the following in "OpenFOAM-2.3.x / src / OpenFOAM / db / Time / Time.C." Code:
bool Foam::Time::run() const While I have never tried executing them elsewhere, I see that the Time class does have a getter for the functionObjects list, so you should be able to retrieve that list and thus execute functionObjects whenever you want. So something like... Code:
runTime.functionObjects().execute(); To only execute a specific functionObject, you need to do something like... Code:
label id = runTime.functionObjects().findObjectID(name); //Warning: returns -1 if "name" does not exist. OpenFOAM-2.3.x / src / OpenFOAM / db / functionObjects / functionObjectList / functionObjectList.C and "forceWrite" is an optional boolean with defaults 'false'. Disclaimer: I did not test the above code (I don't have access to OF right now). I reasoned from the source code. Try it yourself. |
Is there any way I can access forces in the solver ? |
It is an old question, but for the people who might be interested (Based on OpenFOAM-v2007): I can see that Kevin answered the question correctly. Just to put it in another way, the functionObjects are called inside the run() function from the time class. For example, let's consider the pimpleFoam solver. The solver loop starts with: Code:
while (runTime.run()) Code:
if (timeIndex_ == startTimeIndex_) Therefore, the functionObjects are called at the beginning of each loop and not at the end. In this way, they are also called after the final time step. The simpleFoam solver is also similar. But first the loop() function is called and the run() function is called inside the loop(). Best Saeed |
Hi Saeed, I know this post belongs to some time ago, and now we know where functionObjects are triggered. However, this brings an important question about functionObjects. The question is about how to have access to a function in a functionObject? I have a "forces" functionObject which writes the postProcessing files at the end of time step and also within the terminal. I am using OF 5.x, which is showing me this function for output files in the forces.C: Code:
bool Foam::functionObjects::forces::write() Code:
Foam::vector Foam::functionObjects::forces::forceEff() const Hint: I have seen its usage in rigidBodyMeshMotion. Thank you for your help and consideration. |
Hi there, I have the same question as you do. Have you successfully called this forceEff function? I really dont know how to do it:(
