vitorspadetoventurin |
November 27, 2014 20:30 |
typing wmake gives...:
a@a-Aspire-V3-571:/opt/openfoam230/src/transportModels/incompressible/viscosityModels/BirdCarreau$ wmake
wmake: 'Make' directory does not exist in /opt/openfoam230/src/transportModels/incompressible/viscosityModels/BirdCarreau
Searching up directories tree for Make directory
Found target directory ./../..
Making dependency list for source file viscosityModels/viscosityModel/viscosityModel.C
Making dependency list for source file viscosityModels/viscosityModel/viscosityModelNew.C
Making dependency list for source file viscosityModels/Newtonian/Newtonian.C
Making dependency list for source file viscosityModels/powerLaw/powerLaw.C
Making dependency list for source file viscosityModels/CrossPowerLaw/CrossPowerLaw.C
Making dependency list for source file viscosityModels/BirdCarreau/BirdCarreau.C
Making dependency list for source file viscosityModels/HerschelBulkley/HerschelBulkley.C
Making dependency list for source file transportModel/transportModel.C
Making dependency list for source file singlePhaseTransportModel/singlePhaseTransportModel.C
Making dependency list for source file incompressibleTwoPhaseMixture/incompressibleTwoPhaseMixture.C
SOURCE=viscosityModels/viscosityModel/viscosityModel.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-100 -I.. -I../twoPhaseMixture/lnInclude -I/opt/openfoam230/src/finiteVolume/lnInclude -IlnInclude -I. -I/opt/openfoam230/src/OpenFOAM/lnInclude -I/opt/openfoam230/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/viscosityModel.o
SOURCE=viscosityModels/viscosityModel/viscosityModelNew.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-100 -I.. -I../twoPhaseMixture/lnInclude -I/opt/openfoam230/src/finiteVolume/lnInclude -IlnInclude -I. -I/opt/openfoam230/src/OpenFOAM/lnInclude -I/opt/openfoam230/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/viscosityModelNew.o
SOURCE=viscosityModels/Newtonian/Newtonian.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-100 -I.. -I../twoPhaseMixture/lnInclude -I/opt/openfoam230/src/finiteVolume/lnInclude -IlnInclude -I. -I/opt/openfoam230/src/OpenFOAM/lnInclude -I/opt/openfoam230/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/Newtonian.o
SOURCE=viscosityModels/powerLaw/powerLaw.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-100 -I.. -I../twoPhaseMixture/lnInclude -I/opt/openfoam230/src/finiteVolume/lnInclude -IlnInclude -I. -I/opt/openfoam230/src/OpenFOAM/lnInclude -I/opt/openfoam230/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/powerLaw.o
SOURCE=viscosityModels/CrossPowerLaw/CrossPowerLaw.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-100 -I.. -I../twoPhaseMixture/lnInclude -I/opt/openfoam230/src/finiteVolume/lnInclude -IlnInclude -I. -I/opt/openfoam230/src/OpenFOAM/lnInclude -I/opt/openfoam230/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/CrossPowerLaw.o
SOURCE=viscosityModels/BirdCarreau/BirdCarreau.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-100 -I.. -I../twoPhaseMixture/lnInclude -I/opt/openfoam230/src/finiteVolume/lnInclude -IlnInclude -I. -I/opt/openfoam230/src/OpenFOAM/lnInclude -I/opt/openfoam230/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/BirdCarreau.o
SOURCE=viscosityModels/HerschelBulkley/HerschelBulkley.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-100 -I.. -I../twoPhaseMixture/lnInclude -I/opt/openfoam230/src/finiteVolume/lnInclude -IlnInclude -I. -I/opt/openfoam230/src/OpenFOAM/lnInclude -I/opt/openfoam230/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/HerschelBulkley.o
SOURCE=transportModel/transportModel.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-100 -I.. -I../twoPhaseMixture/lnInclude -I/opt/openfoam230/src/finiteVolume/lnInclude -IlnInclude -I. -I/opt/openfoam230/src/OpenFOAM/lnInclude -I/opt/openfoam230/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/transportModel.o
SOURCE=singlePhaseTransportModel/singlePhaseTransportModel.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-100 -I.. -I../twoPhaseMixture/lnInclude -I/opt/openfoam230/src/finiteVolume/lnInclude -IlnInclude -I. -I/opt/openfoam230/src/OpenFOAM/lnInclude -I/opt/openfoam230/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/singlePhaseTransportModel.o
SOURCE=incompressibleTwoPhaseMixture/incompressibleTwoPhaseMixture.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-100 -I.. -I../twoPhaseMixture/lnInclude -I/opt/openfoam230/src/finiteVolume/lnInclude -IlnInclude -I. -I/opt/openfoam230/src/OpenFOAM/lnInclude -I/opt/openfoam230/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/incompressibleTwoPhaseMixture.o
'/opt/openfoam230/platforms/linux64GccDPOpt/lib/libincompressibleTransportModels.so' is up to date.
I made other modification (that I forgot to change before) and typed again the command wmake and gives:
Is it OK? Or not? Now, Can I just run my case with my changed Carreau viscosity model ?
I just modified the value of a constant in BirdCarreau.C
