In pointPatchField, how to read coordinate values of mesh |
December 18, 2014, 08:35 |
Jarvis
Rep Power: 12 |
Hello foamers:
I want to write a new boundary based on oscillatingDisplacementPointPatchField. I want to give this boundary different values based on the mesh's coordinate values. Not a single value of the patch's coordinate, I mean different values on different girds. In this field, I can't use mesh.C() because "mesh" is not defined. Do you have any idea? Thank you! |
December 18, 2014, 08:58 |
Kevin van As
Rep Power: 20 |
I don't understand exactly what you are trying to do, but
http://www.cfd-online.com/Forums/ope...-registry.html that topic shows how you can access the mesh. I hope that helps. |
December 19, 2014, 06:16 |
#3 | |
Jarvis
Rep Power: 12 |
Thank you for your reply! I will try the methods in that thread, thank you. |
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 07:38 |
Mesh Boundary Assignment Question | Wandadars | Mesh Generation & Pre-Processing | 1 | June 13, 2016 17:19 |
[Other] Cannot read a Spider mesh into Foam | evrikon | OpenFOAM Meshing & Mesh Conversion | 1 | March 14, 2012 10:13 |
Mesh Reference Values problem. | rezki | STAR-CCM+ | 7 | July 19, 2010 05:30 |
[snappyHexMesh] external flow with snappyHexMesh | chelvistero | OpenFOAM Meshing & Mesh Conversion | 11 | January 15, 2010 19:43 |
