wenxu |
December 12, 2014 04:23 |
Duplicate entry SpalartAllmaras in runtime selection table LESModel
Hello,everyone.
I encounter the problem which had troubled me for some time, and i also searched the forum but i did not get any clear answer. So i started a new post here. Every one could give me some suggestions even if you did not encounter this problem.:)
My Make/options is as follows:
EXE_INC = \
-I$(LIB_SRC)/finiteVolume/lnInclude \
-I$(LIB_SRC)/lagrangian/basic/lnInclude \
-I$(LIB_SRC)/meshTools/lnInclude \
-I$(LIB_SRC)/sampling/lnInclude \
-I$(LIB_FLAMELETPCC_SRC)/turbulenceModels/compressible/turbulenceModel \
-I/root/OpenFOAM/root-2.3.0/src/flameletPCC/flameletIntermediate/lnInclude \
-I/root/OpenFOAM/root-2.3.0/src/flameletPCC/coalCombustion/lnInclude \
-I$(LIB_FLAMELETPCC_SRC)/thermophysicalModels/specie/lnInclude \
-I$(LIB_FLAMELETPCC_SRC)/thermophysicalModels/basic/lnInclude \
-I$(LIB_FLAMELETPCC_SRC)/thermophysicalModels/reactionThermo/lnInclude \
-I$(LIB_FLAMELETPCC_SRC)/thermophysicalModels/chemistryModel/lnInclude \
-I$(LIB_SRC)/thermophysicalModels/properties/liquidProperties/lnInclude \
-I$(LIB_SRC)/thermophysicalModels/properties/liquidMixtureProperties/lnInclude \
-I$(LIB_SRC)/thermophysicalModels/properties/solidProperties/lnInclude \
-I$(LIB_SRC)/thermophysicalModels/properties/solidMixtureProperties/lnInclude \
-I$(LIB_SRC)/thermophysicalModels/SLGThermo/lnInclude \
-I$(LIB_SRC)/regionModels/regionModel/lnInclude \
-I$(LIB_SRC)/regionModels/surfaceFilmModels/lnInclude \
-I$(LIB_FLAMELETPCC_SRC)/combustionModels/lnInclude
EXE_LIBS = \
-L$(FOAM_USER_LIBBIN) \
-lFlameletPCCcompressibleTurbulenceModel \
-lFlameletPCCcompressibleLESModels \
-lFlameletPCCcompressibleRASModels \
-lFlameletPCCreactionThermophysicalModels \
-lFlameletPCCspecie \
-lFlameletPCCbasicThermophysicalModels \
-lFlameletPCCchemistryModel \
-lfiniteVolume \
-lmeshTools \
-lsampling \
-lflameletPCCintermediate \
-lflameletPCCcoalCombustion\
-lFlameletPCCCombustionModels
Where the LIB_FLAMELETPCC_SRC is the envierment to my local src case.
The library was compiled with no problem, but when i run the solver , I encounter the following error:
#0 /opt/openfoam230/platforms/linuxGccDPOpt/lib/libOpenFOAM.so(_ZN4Foam5error14safePrintStackERSo+ 0x29) [0xb4893ca9]
#1 /root/OpenFOAM/root-2.3.0/platforms/linuxGccDPOpt/lib/libFlameletPCCcompressibleLESModels.so(+0x448f3) [0xb76158f3]
#2 /lib/ld-linux.so.2(+0xeeab) [0xb77a8eab]
#3 /lib/ld-linux.so.2(+0xef94) [0xb77a8f94]
#4 /lib/ld-linux.so.2(+0x120f) [0xb779b20f]
Duplicate entry vanDriest in runtime selection table foamLESdelta
#1 /root/OpenFOAM/root-2.3.0/platforms/linuxGccDPOpt/lib/libFlameletPCCcompressibleLESModels.so(+0x44b0b) [0xb7615b0b]
Many errors to list here.
The second error is as follows:
Selecting turbulence model type LESModel
Selecting LES turbulence model Smagorinsky
Selecting LES delta type vanDriest
Selecting LES delta type cubeRootVol
#0 Foam::error::printStack(Foam::Ostream&) in "/opt/openfoam230/platforms/linuxGccDPOpt/lib/libOpenFOAM.so"
#1 Foam::sigSegv::sigHandler(int) in "/opt/openfoam230/platforms/linuxGccDPOpt/lib/libOpenFOAM.so"
#2 Uninterpreted:
#3 Foam::compressible::LESModels::Smagorinsky::update SubGridScaleFields(Foam::GeometricField<Foam::Tens or<double>, Foam::fvPatchField, Foam::volMesh> const&) in "/root/OpenFOAM/root-2.3.0/platforms/linuxGccDPOpt/lib/libFlameletPCCcompressibleLESModels.so"
#4 Foam::compressible::LESModels::Smagorinsky::Smagor insky(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::fluidThermo const&, Foam::word const&, Foam::word const&) in "/opt/openfoam230/platforms/linuxGccDPOpt/lib/libcompressibleLESModels.so"
#5 Foam::compressible::LESModel::adddictionaryConstru ctorToTable<Foam::compressible::LESModels::Smagori nsky>::New(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::fluidThermo const&, Foam::word const&) in "/opt/openfoam230/platforms/linuxGccDPOpt/lib/libcompressibleLESModels.so"
#6 Foam::compressible::LESModel::New(Foam::GeometricF ield<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::fluidThermo const&, Foam::word const&) in "/opt/openfoam230/platforms/linuxGccDPOpt/lib/libcompressibleLESModels.so"
#7 Foam::compressible::turbulenceModel::addturbulence ModelConstructorToTable<Foam::compressible::LESMod el>::NewturbulenceModel(Foam::GeometricField<doubl e, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::fluidThermo const&, Foam::word const&) in "/opt/openfoam230/platforms/linuxGccDPOpt/lib/libcompressibleLESModels.so"
#8 Foam::compressible::turbulenceModel::New(Foam::Geo metricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::fluidThermo&, Foam::word const&) in "/root/OpenFOAM/root-2.3.0/platforms/linuxGccDPOpt/lib/libFlameletPCCcompressibleTurbulenceModel.so"
Please give me some suggestions. Thank you in advance!
regards,
wen
