November 4, 2014, 06:15 |
Strange crash, possibly memory related
Rep Power: 18 |
I'm currently writing a boundary condition based on TemperatureCoupledBase and I'm seeing a crash when I try to call its kappa(const scalarField& Tp) function. It gives a segv error in the field addition in heThermo::alphaEff(const scalarField& alphat, const label patchi) function. However, when I add a simple console output, Info << "test " <<endl; here, to an intermediate function (in RASModel.H, kappaEff(const label patchI) ) or directly in my solver, it does not crash anymore. Furthermore, the kappa function from TemperatureCoupledBase is called multiple times in the BC without crashing.
This smells very fishy and I suspect memory corruption or similar things (maybe incompatibility between compiled libraries?). Any suggestions how one can tackle such a problem? I should add one more thing, I'm using a custom thermophysical library. The turbulenceModels reference the default thermophysical library, can this be a problem? I have tried compiling them with referencing only my own library, but this didn't change anything. |
November 4, 2014, 07:39 |
Rep Power: 18 |
Changing the number of pimple iterations also avoids this crash...
I had to change something in the boundary condition which also prevents crashing, so it's currently running, but I fear that there is some kind of hidden memory corruption which will give me problems later on or maybe lead to wrong results, so I'm not happy with the status quo. |
November 8, 2014, 16:45 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings chriss85,
Not enough information to diagnose the actual problem, so guessing is the only thing that can be done here: you were probably not using properly an access by reference to a field/variable. If accesses are made too many times without relying on an intermediate reference variable, it could lead to memory problems, at least when running in parallel. Best regards, Bruno |
November 10, 2014, 06:28 |
Rep Power: 18 |
The crash is also happening on single threaded runs.
Anything I can provide for better diagnosis? The thermophysical library itself doesn't use any references in the kappa() function in which it crashes, it just uses some member variables of the class. With not using an intermediate reference variable, do you mean copying the value/object using a copy constructor? If so, why is this going to lead to memory problems? I can see why it would be inefficient, but crashing? |
November 10, 2014, 16:40 |
Bruno Santos
Rep Power: 128 |
Quick answers:
A code snapshot? Allow us to see what you're seeing? Show us what modifications you've made? Even if it you don't show specific implemented equations, a mock-up of the code would give some more ideas on what you have in front of you OpenFOAM relies on a very automated parallellization mechanism, which means that excessive requests of a particular field, can lead to overlapping requests for communicating in parallel. Either that, or flood the stack of pending communications. |
November 11, 2014, 03:33 |
Rep Power: 18 |
I will post some excerpts later, though I don't think it will be possible to post the whole code, as it is too involved and not so easy to set up.
November 13, 2014, 02:35 |
Rep Power: 18 |
Here's the code of the BC in which the crash happened. (Un)fortunately, in this current version the crash is not happening anymore. I took a close look at the changes when I made them and I'm relatively sure the cause wasn't due to them, so maybe there is still something in there. This is a region coupled BC which limits the temperature to an evaporation temperature.
void TemperatureRadCoupledMixedLimitedFvPatchScalarField::updateCoeffs() { if (updated()) { return; } // Since we're inside initEvaluate/evaluate there might be processor // comms underway. Change the tag we use. int oldTag = UPstream::msgType(); UPstream::msgType() = oldTag+1; // Get the coupling information from the mappedPatchBase const mappedPatchBase& mpp = refCast<const mappedPatchBase>(patch().patch()); const polyMesh& nbrMesh = mpp.sampleMesh(); const label samplePatchI = mpp.samplePolyPatch().index(); const fvPatch& nbrPatch = refCast<const fvMesh>(nbrMesh).boundary()[samplePatchI]; scalarField& Tp = *this; const TemperatureRadCoupledMixedLimitedFvPatchScalarField& nbrField = refCast <const TemperatureRadCoupledMixedLimitedFvPatchScalarField> ( nbrPatch.lookupPatchField<volScalarField, scalar>(TnbrName_) ); // Swap to obtain full local values of neighbour internal field scalarField TcNbr(nbrField.patchInternalField()); //Note: distributing (-->interpolating) from one mesh to another of a directional quantity such as Qr // does not reverse the sign due to changing surface normal mpp.distribute(TcNbr); // Swap to obtain full local values of neighbour K*delta tmp<scalarField> KDeltaNbr(new scalarField(TcNbr.size(), 0.0)); if (contactRes_ == 0.0) { // Swap to obtain full local values of neighbour K*delta KDeltaNbr() = nbrField.kappa(nbrField)*nbrPatch.deltaCoeffs(); } else { KDeltaNbr() = contactRes_; } mpp.distribute(KDeltaNbr()); scalarField KDelta(kappa(*this)*patch().deltaCoeffs()); scalarField Qr(Tp.size(), 0.0); if (QrName_ != "none") { Qr = patch().lookupPatchField<volScalarField, scalar>(QrName_); } scalarField QrNbr(Tp.size(), 0.0); if (QrNbrName_ != "none") { QrNbr = nbrPatch.lookupPatchField<volScalarField, scalar>(QrNbrName_); mpp.distribute(QrNbr); } scalarField alpha(KDeltaNbr() - (Qr + QrNbr)/Tp); valueFraction() = alpha/(alpha + KDelta); refValue() = (KDeltaNbr()*TcNbr)/alpha; forAll(*this, faceI) { //Evaluating the value directly works better here. if(valueFraction()[faceI]*refValue()[faceI]+(1-valueFraction()[faceI])*patchInternalField()()[faceI] > T_Evap_) { valueFraction()[faceI] = 1; refValue()[faceI] = T_Evap_; Info << "limiting temperature at patch to evaporation temperature " << T_Evap_ << endl; } } mixedFvPatchScalarField::updateCoeffs(); tmp<scalarField> QNbr(new scalarField(TcNbr.size(), 0.0)); // Swap to obtain full local values of neighbour K*delta //Second minus because the snGrad of neighbour field points in the wrong direction QNbr() = - (- nbrField.kappa(nbrField) * nbrField.snGrad()); mpp.distribute(QNbr()); Info << "patch: " << patch().name() << ", min T: " << min(Tp) << endl; //Info << "patch: " << patch().name() << ", dQ: " << sqrt(pow((min(Qr) - min(kappa(*this)*snGrad()) - (min(QNbr) - min(QrNbr)))/(min(-kappa(*this)*snGrad())), 2)) << endl; //The crash happened in this line Info << "patch: " << patch().name() << ", kappa: " << min(kappa(*this)) << endl; Info << "patch: " << patch().name() << ", deltaCoeffs: " << min(patch().deltaCoeffs()) << endl; Info << "patch: " << patch().name() << ", Tcenter: " << min(patchInternalField()) << endl; Info << "patch: " << patch().name() << ", Qr: " << std::abs(min(Qr)) << endl; //Info << "patch: " << patch().name() << ", Q: " << std::abs(min(-kappa(*this)*snGrad())) << endl; //Info << "patch: " << patch().name() << ", QTotal: " << std::abs(min(-kappa(*this)*snGrad() + Qr)) << endl; Info << "patch: " << patch().name() << ", alpha: " << min(alpha) << endl; Info << "patch: " << patch().name() << ", refValue: " << refValue() << endl; //Qr is positive for outgoing radiation, QrNbr is positive for radiation from wall to plasma /* evaporationHeatFlux_ = (- kappa(*this) * snGrad() + Qr) - (-(QNbr) - QrNbr); */ if (debug) { scalar Q = gSum(kappa(*this)*patch().magSf()*snGrad()); Info<< patch().boundaryMesh().mesh().name() << ':' << patch().name() << ':' << this->dimensionedInternalField().name() << " <- " << nbrMesh.name() << ':' << nbrPatch.name() << ':' << this->dimensionedInternalField().name() << " :" << " heat transfer rate:" << Q << " walltemperature " << " min:" << gMin(*this) << " max:" << gMax(*this) << " avg:" << gAverage(*this) << endl; } // Restore tag UPstream::msgType() = oldTag; } |
November 16, 2014, 17:10 |
#8 | |
Bruno Santos
Rep Power: 128 |
Hi chriss85,
My guess is that you're triggering the exact thing I was trying to indicate, but that you're currently no longer triggering, only because you now probably have less calls being made. From what I can see on this excerpt of code (thanks for making a big excerpt, since it's easier to diagnose this way), the problem is that you're not using something like this: Code:
const fvPatch& nbrPatch = refCast<const fvMesh>(nbrMesh).boundary()[samplePatchI]; Code:
const scalarField & nbrFieldKappa = nbrField.kappa(nbrField); const scalarField & localKappa = kappa(*this); If the last "kappa()" you're referring to is the one inside the "if(debug)" block, then the "gSum" can easily be the thing that broke the camel's back, because it's a function that takes care of doing a parallel summation, which requires more intermediate variables that you might be expecting. If you can make it break again (use a more refined mesh if you have to, at least make the patches have more cell-faces), then try the solution I mentioned a few lines above and it will possibly fix the problem. Best regards, Bruno |
November 17, 2014, 06:05 |
#9 |
Rep Power: 18 |
Are you saying that this can also happen without parallel running?
I don't know too much about the internals of the OpenFOAM code, so I don't know about this for sure. Values which are needed temporarily inside a statement should be allocated on the stack and be deallocated at the end of the scope. OpenFOAM uses the tmp class to wrap objects which normally appear on the stack, so they can be on the heap (which is faster because the tmp object which is on the stack can be copied without penalties). I could possibly see an issue with the tmp<> class, but I did not look into its implementation so I can't tell for sure. The crash was happening in the line which I commented, before the debugging code. |
November 17, 2014, 14:56 |
#10 | |
Bruno Santos
Rep Power: 128 |
I went back to read again your first post and it seems that the crash would occur when "kappa" was calling "heThermo::alphaEff" midway. Without being able to test myself, my guess is that the crash occurs because there is a long operation going on in that particular line. If you split up the operation in two or three steps, would it still crash in the same way? Namely something like this: Code:
evaporationHeatFlux_ = -kappa(*this) * snGrad(); evaporationHeatFlux_ += Qr; evaporationHeatFlux_ += QNbr + QrNbr; It's also possible that this is an optimization glitch made by the compiler and/or linker. In addition, "heThermo::alphaEff" is possibly something within a heavily source code C++ template section of the code. If any changes were made to any single one of those template files and which is used in both:
Now that I think about it, right now this is indeed the 1st or 2nd most likely suspect... Best regards, Bruno |
January 12, 2015, 11:26 |
#11 |
Rep Power: 14 |
I found your thread and maybe there is also a relation to this recent bugfix: turbulentTemperatureRadCoupledMixedFvPatchScalarFi eld::updateCoeffs(): refValue can become negative. http://www.openfoam.org/mantisbt/view.php?id=1369 best regards dirk |
Memory/ swap area | J-man | STAR-CD | 1 | September 29, 2009 19:43 |
Unusual memory related error | ReeKo | CFX | 7 | September 30, 2008 19:11 |
CFX 5.6 memory problem with solver | sreevisakh | CFX | 3 | February 2, 2004 04:57 |
Memory allocation problem | shhe | CFX | 4 | January 6, 2004 23:00 |
ECC Memory Needed for Clusters? | Jonas Larsson | Main CFD Forum | 1 | January 17, 2001 08:08 |
