How to get access to the functions inside the shared libraries in OpenFOAM
Like Tree6Likes
  • 6 Post By tomislav_maric
Old   February 10, 2015, 09:24
Default How to get access to the functions inside the shared libraries in OpenFOAM
Mohsen Ranjbaran
mohsenCFDonline is on a distinguished road
Dear all
Does anyone knows how I can get access to the functions inside the shared libraries (.so) in OpenFOAM?
Regards
Mohsen
mohsenCFDonline is offline   Reply With Quote
Old   February 11, 2015, 06:21
Blanco
Blanco is on a distinguished road
Yes, you can find the source of the lib under the src dir.
Use this as an example:
grep -R libforces.so $FOAM_SRC
You will get many results that can be used to identify "where" is the source code for libforces.so (in this case src/postProcessing/functionObjects/forces)
Regards
Blanco is offline   Reply With Quote
Old   March 25, 2015, 03:56
haze_1986 is on a distinguished road
Hi, I think he meant accessing variables of the objects created in the libraries?
haze_1986 is offline   Reply With Quote
Old   March 25, 2015, 04:36
Tomislav Maric
tomislav_maric is on a distinguished road
A library is a bunch of object code, containing the translation of the C++ we humans write to machine language. Basically, every OpenFOAM utility accesses library functions, whose implementation is stored in the .so file.
If you are writing your utility, all you need to do is to include the header:
#include "someClass.H"
use the library in the utiliity application
someClass someObject;
someObject.someMemberFunction();
And that is it. The linker program will take care of linking your utility application with the appropriate .so object file. That is why you need to edit `Make/options` and provide something along these lines:
-I/path/to/library/lnInclude
-L/path/to/library/file
-lsomeLibrary
In order for `wmake` to tell the linker where the library file is located, and set up the compiler to know where to find `someLibrary.H`.
If you are using function objects, you will be doing this automatically. Still, you need to add something like `functionObjectsLibs ("libsomeLibrary.so")` in the control dict.
Btw, what exactly do you want to do?
Elham, rafa13, elmo555 and 3 others like this.
When asking a question, prepare a SSCCE.
tomislav_maric is offline   Reply With Quote
time functions in openFoam? cyberbrain OpenFOAM Running, Solving & CFD 6 November 2, 2015 21:25
parallel running - error while loading shared libraries: seami OpenFOAM Installation 1 December 9, 2011 04:39
Access source code of OpenFOAM nmansouri OpenFOAM 1 October 14, 2010 02:17
Can't profile shared libraries rsamuel OpenFOAM Programming & Development 1 August 3, 2009 09:58
64bitrhel5 OF installation instructions mirko OpenFOAM Installation 2 August 12, 2008 18:07
