February 18, 2015, 18:46 |
Parallelization of code
Evangelos
Rep Power: 14 |
Hello
I write,add a piece of a code in ParamagneticForce.C. Although the results are very good in serial processing there is a big difference in parallel. I think that after the decomposition of the geometry the processors are worked only in the domain that they are obligated and not communicate with each other. Is this true? Am i missing something ? If this is true , how can i fix the problem ? is there any tutorial ? the version that i use is OF 2.2.1 |
February 19, 2015, 02:38 |
If you would like to get general answer, then yes, you are right, you are missing something. If you post the code you have added, people will be able to tell you how to change it to make it run correctly in parallel. |
The FOAM Documentation Project - SHUT-DOWN | holger_marschall | OpenFOAM | 242 | March 7, 2013 12:30 |
How to make code run in parallel? | cwang5 | OpenFOAM Programming & Development | 1 | May 30, 2011 04:47 |
Open Source Vs Commercial Software | MechE | OpenFOAM | 28 | May 16, 2011 11:02 |
Small 3-D code | Zdravko Stojanovic | Main CFD Forum | 2 | July 19, 2010 10:11 |
public CFD Code development | Heinz Wilkening | Main CFD Forum | 38 | March 5, 1999 11:44 |
