error while doing 'wmake'
Foamers,
I am doing a work based on twoPhaseEulerFoam. I am investigating the solver now. For running the solver I have done 'wmake' on the solver. But I found the following error while doing that. Please help. Thanks in advance. Making dependency list for source file twoPhaseEulerFoam.C SOURCE=twoPhaseEulerFoam.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-100 -I/home/p2tf13007/OpenFOAM/OpenFOAM-2.2.2/src/finiteVolume/lnInclude -I/home/p2tf13007/OpenFOAM/OpenFOAM-2.2.2/src/transportModels/incompressible/lnInclude -IturbulenceModel -IkineticTheoryModels/lnInclude -IinterfacialModels/lnInclude -IphaseModel/lnInclude -Iaveraging -IlnInclude -I. -I/home/p2tf13007/OpenFOAM/OpenFOAM-2.2.2/src/OpenFOAM/lnInclude -I/home/p2tf13007/OpenFOAM/OpenFOAM-2.2.2/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/twoPhaseEulerFoam.o In file included from twoPhaseEulerFoam.C:50:0: wallEvap.H:2:31: error: ‘mesh’ was not declared in this scope const fvPatchList& patches = mesh.boundary(); ^ In file included from /home/p2tf13007/OpenFOAM/OpenFOAM-2.2.2/src/OpenFOAM/lnInclude/List.H:43:0, from /home/p2tf13007/OpenFOAM/OpenFOAM-2.2.2/src/OpenFOAM/lnInclude/labelList.H:48, from /home/p2tf13007/OpenFOAM/OpenFOAM-2.2.2/src/OpenFOAM/lnInclude/UPstream.H:43, from /home/p2tf13007/OpenFOAM/OpenFOAM-2.2.2/src/OpenFOAM/lnInclude/Pstream.H:42, from /home/p2tf13007/OpenFOAM/OpenFOAM-2.2.2/src/OpenFOAM/lnInclude/parRun.H:35, from /home/p2tf13007/OpenFOAM/OpenFOAM-2.2.2/src/finiteVolume/lnInclude/fvCFD.H:4, from twoPhaseEulerFoam.C:33: /home/p2tf13007/OpenFOAM/OpenFOAM-2.2.2/src/OpenFOAM/lnInclude/UList.H:395:5: error: expected unqualified-id before ‘for’ for (Foam::label i=0; i<(list).size(); i++) ^ wallEvap.H:3:2: note: in expansion of macro ‘forAll’ forAll(patches, patchi) ^ wallEvap.H:3:18: error: ‘patchi’ does not name a type forAll(patches, patchi) ^ /home/p2tf13007/OpenFOAM/OpenFOAM-2.2.2/src/OpenFOAM/lnInclude/UList.H:395:27: note: in definition of macro ‘forAll’ for (Foam::label i=0; i<(list).size(); i++) ^ wallEvap.H:3:18: error: ‘patchi’ does not name a type forAll(patches, patchi) ^ /home/p2tf13007/OpenFOAM/OpenFOAM-2.2.2/src/OpenFOAM/lnInclude/UList.H:395:44: note: in definition of macro ‘forAll’ for (Foam::label i=0; i<(list).size(); i++) ^ In file included from twoPhaseEulerFoam.C:50:0: wallEvap.H:67:25: error: ‘mEvap’ was not declared in this scope volScalarField mTotal = mEvap - mCondsn; ^ wallEvap.H:67:33: error: ‘mCondsn’ was not declared in this scope volScalarField mTotal = mEvap - mCondsn; ^ In file included from twoPhaseEulerFoam.C:65:0: /home/p2tf13007/OpenFOAM/OpenFOAM-2.2.2/src/finiteVolume/lnInclude/readTimeControls.H: In function ‘int main(int, char**)’: /home/p2tf13007/OpenFOAM/OpenFOAM-2.2.2/src/finiteVolume/lnInclude/readTimeControls.H:38:8: warning: unused variable ‘maxDeltaT’ [-Wunused-variable] scalar maxDeltaT = ^ make: *** [Make/linux64GccDPOpt/twoPhaseEulerFoam.o] Error 1 |
Main reason for the errors is Code:
wallEvap.H:2:31: error: ‘mesh’ was not declared in this scope |
