problem in defining the field
Old   March 15, 2015, 08:17
Post problem in defining the field
Muhammad Usman
13msmemusman is on a distinguished road
i entered following equation in interFoam.C
CoM = sum(rho*mesh.V()*mesh.C().dimensionedInternalField ())/sum(rho*mesh.V());
then defined it in creatFields.H as following
dimensionedVector CoM("CoM", dimLength, vector::zero);
then i compiled it works well. but now i want to take its gradient. i wrote
gradCoM = grad (CoM);
and defined it in creatFields.H as following
uniformDimensionedVectorField gradCoM("gradCoM", dimLength, vector::zero);
now it gives following error please help
In file included from myInterFoamDDT.C:60:0:
createFields.H: In function ‘int main(int, char**)’:
createFields.H:2:73: error: no matching function for call to ‘Foam::UniformDimensionedField<Foam::Vector<double > >::UniformDimensionedField(const char [8], const Foam::dimensionSet&, const Foam::Vector<double>&)’
one thing is obvious in my views that problem is in defining the field as UniformDimensionedField...... please help
13msmemusman is offline   Reply With Quote
Old   March 15, 2015, 12:17
Bruno Kassar
bkassar is on a distinguished road
Hi Muhammad,
The compiler is complaining about the constructor of uniformDimensionedVectorField.
However, I think your main problem is not that.
The main issue is that you are trying to compute the gradient of a vector. Notice that the variable 'CoM' is not a Field.
cheers,
Bruno
bkassar is offline   Reply With Quote
Old   March 16, 2015, 01:12
Mattia de\' Michieli Vitturi
demichie is on a distinguished road
In addition if you have a field A the gradient of A should have the units of A divided by the unit of lenght.
Ciao
Mattia
demichie is offline   Reply With Quote
Old   March 16, 2015, 10:26
Post
Muhammad Usman
Sir you are right that its not a field. i am taking gradient of a vector. then what should i use instead of DimensionedVector???? actually i read that gradient of a vector is a tensor thats why i wrote that
Old   March 16, 2015, 11:08
Bruno Kassar
Hi Muhammad,
As far as I see, you computed the center of mass and stored it in 'CoM'.
Could you tell us what you want to compute?
It is not clear to me why you need the gradient...
cheers,
Bruno
Old   March 16, 2015, 11:13
Post
Muhammad Usman
Sir i want to take double derivative of every component of this vector as i have to put it in a formulae
Old   March 16, 2015, 11:15
Post
Muhammad Usman
Sir i want to take double derivative of every component of this vector as i have to put it in a formulae. i am sorry at first i was wrong. i was thinking that formulae requires double spacial derivative of COM completely. i want to take double derivative of every component of CoM. thank you sir
Old   March 16, 2015, 11:30
Bruno Kassar
I see. So, by double derivative you mean double derivative with respect to time? You want the acceleration of this center of mass?
If the answer is yes, you could store the values of CoM in three different time steps and perform the derivatives by a second-order differencing scheme you may choose.
Hope that helps.
Old   March 16, 2015, 12:26
Post
Muhammad Usman
sir i stored components of Varible CoM in 3 different varibles in following way
Info << "Center of Mass " << CoM.dimensions() << " = " << CoM << nl << endl;
vector CoMx = CoM.x();
vector CoMy = CoM.y();
vector CoMz = CoM.z();
but it gives following error
myInterFoamDDT.C: In function ‘int main(int, char**)’:
myInterFoamDDT.C:111:19: error: ‘Foam::dimensionedVector’ has no member named ‘x’
myInterFoamDDT.C:112:19: error: ‘Foam::dimensionedVector’ has no member named ‘y’
myInterFoamDDT.C:113:19: error: ‘Foam::dimensionedVector’ has no member named ‘z’
Please help me.
Old   March 17, 2015, 10:26
Muhammad Usman
please help
Old   March 17, 2015, 14:07
Bruno Kassar
Hi Muhammad,
The second derivative you want to take is with respect to time?
Old   March 18, 2015, 10:17
Post
  #12
Muhammad Usman
yes sir its with respect to time
Old   March 18, 2015, 10:32
Muhammad Usman
The problem specified above is solved.... now i just want to take its derivative with respect to time. means i need acceleration of center of mass.
Old   March 18, 2015, 12:43
Bruno Kassar
So now, you just need the value of CoM at three consecutive time steps; let's say CoM(i-2), CoM(i-1) and CoM(i). Choose a second-order differencing scheme and use these three values to obtain the acceleration. There are many ways to do it. The easiest one would be the second-order backward scheme. For your problem, it would give something like:
A = (CoM(i)-2*CoM(i-1)+CoM(i-2))/(dt^2)
Hope that helps!
cheers,
Bruno
Old   March 18, 2015, 12:49
Post
  #15
Muhammad Usman
Thank you very much sir....
field creatfields.h
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 06:20
Defining convergent gravity field! please Help me adambarfi OpenFOAM 24 August 1, 2012 12:34
Defining "cyclic" B.C. problem maysmech OpenFOAM 20 March 14, 2011 10:28
Surface Vector Field Problem at Parallel cwang5 OpenFOAM Bugs 6 July 12, 2010 08:31
Aeroacustic problem in Automotive field Gabriele Velenich Main CFD Forum 5 December 11, 2001 03:43
