Why we subtract continuity Eqn into momentum Eqn instead of adding it?
Like Tree1Likes
  • 1 Post By Cyp
Old   April 27, 2015, 03:14
Default Why we subtract continuity Eqn into momentum Eqn instead of adding it?
Dongyue Li
sharonyue is on a distinguished road
Hey guys,
This piece of code is quite common in OpenFOAM;
 fvm::ddt(alpha1, U1)  //mom eqn
         -fvm::Sp(fvc::ddt(alpha1),U1) //continuity eqn
          + fvm::div(alpha1, U1) //mom eqn
          - fvm::Sp(fvc::div(alpha1), U1) ////continuity eqn
Why dont we add continuity eqn?...like this:..
         +fvm::Sp(fvc::ddt(alpha1),U1) //continuity eqn
          +fvm::Sp(fvc::div(alpha1), U1) ////continuity eqn
continuity is zero right?
sharonyue is offline   Reply With Quote
Old   April 27, 2015, 05:38
ali alkebsi
kebsiali is on a distinguished road
I dont really know
normally we seek diagnal dominance, so i would say so
but thats the contrary of what is done here ??????
kebsiali is offline   Reply With Quote
Old   April 27, 2015, 11:31
Dongyue Li
Yep...Wish someone who can explain this. lol
Old   April 27, 2015, 12:32
Cyp
Cyprien
Cyp is on a distinguished road
Actually, we subtract a momentum transfer term because the real equation (left hand side of NS) we want to solve is
\rho \frac{\partial \mathsf{U}}{\partial t} + \rho  \mathsf{U} . \nabla  \mathsf{U} = (...)
which is written in a non-conservative form. In FVM, however, we prefer conservative form,
\frac{\partial \rho \mathsf{U}}{\partial t} + \nabla.  \left( \rho  \mathsf{U}   \mathsf{U} \right)= (...)
These two equations are not the same if the fluid is not incompressible or if there is phase change. You can notice that you can switch from non-conservative to conservative form with,
\rho \frac{\partial \mathsf{U}}{\partial t} + \rho  \mathsf{U} . \nabla  \mathsf{U}  = \frac{\partial \rho \mathsf{U}}{\partial t} + \nabla.  \left( \rho  \mathsf{U}   \mathsf{U}  \right) -  \left(  \frac{\partial \rho }{\partial t} + \nabla.  \left( \rho  \mathsf{U}  \right) \right)\mathsf{U}
So adding the continuity equation do not have any sense.
Cheers,
wyldckat likes this.
Cyp is offline   Reply With Quote
Old   April 28, 2015, 02:21
Dongyue Li
Originally Posted by Cyp View Post
Cheers,
hey Cyprien,
Yeah, The problem is why we want to solve the first Eqn in your posts. The reason why I ask this kind of problem is that: "openfoam22x is solving non-conservative equations but 23x is solving conservative eqns."for two-fluid model.
So I think the thing deeper is :
1. Why we solve Eqn 2 instead of Eqn 1. I saw some posts that Hrv and Henry explain this, They just said the conservative eqn is stable and good. I dont know the reason.
2. Eqn 2 and Eqn 1 should predicts the same results rite? But sometimes it does not.
Best,
Old   April 28, 2015, 11:39
Cyp
Cyprien
Hi Dongyue,
Eq 1 and Eq 2 are equivalent only if the continuity equation (equal to zero) is satisfy. I guess that since we deal with an operator-splitting scheme (first we solve the momentum, then the pressure, then the correction, then we iterate), the continuity equation is not fully respected, and that why we add to add this term, to avoid spurious momentum transfer due to an ill-evaluation of the continuity.
Cheers,
Old   June 3, 2015, 12:00
Bruno Blais
blais.bruno is on a distinguished road
hey Cyprien,
Best,
Equation 1 and 2 are not equivalent numerically because they do not allow for the same Riemann invariant. If you take the example of a shockwave or any other type of discontinuity, as a Cauchy-Riemann classical problem, you find that the wave propagation / shock propagation/ discontinuity propagation will be at the wrong velocity if you do not formulate your problem using the conserved variables.
I am not familiar with these issues in the context of two phases flows, but for compressible flows this is an extremely critical issue and you always need to formulate the problem in conservative variables (rho, rho * u, rho * e). I believe that since these multiphase flows contain large amount of discontinuity in the phases (like air on top of water or whatever), a conservative formulation is a lot more appropriate if you want to obtain the right propagation of the interface.
There is a very very nice book by Euleterio Toro on hyperbolic systems that discusses these issues if I remember.
blais.bruno is offline   Reply With Quote
Old   June 4, 2015, 05:20
Daniel Witte
danny123 is on a distinguished road
I am confused with these statements. Sharonyue refers to the alpha1Eq, not the momentum equation. In interDymFoam, I have the following code:
        fvScalarMatrix alpha1Eqn
            #ifdef LTSSOLVE
            fv::localEulerDdtScheme<scalar>(mesh, rDeltaT.name()).fvmDdt(alpha1)
            #else
            fv::EulerDdtScheme<scalar>(mesh).fvmDdt(alpha1)
            #endif
          + fv::gaussConvectionScheme<scalar>
                mesh,
                phiCN,
                upwind<scalar>(mesh, phiCN)
            ).fvmDiv(phiCN, alpha1)
which is the same, no?
I changed to:
            #ifdef LTSSOLVE
            #else
            #endif
                mesh,
                phiCN,
          - fvc::div(phi)*fvm::Sp(1,alpha1)
It does not make a whole lot of difference in my case, but the idea is that there are large areas, where alpha1 does not change (only around the interface). In those domains I want interFoam to behave like a single phase solver, so any incosistency in mass conservation should not affect alpha1Eq (d alpha1/dt is 0 if there is no alpha change in space). If alpha1 is constant, the last 2 terms become equivalent. Because div(phi) has to be 0, the ultimate result should be identical. You basically eliminate solving alpha1Eq, where it is not needed (the equation system is overdetermined).
By the way, for compressible solvers, this code is wrong (div phi is not zero, but div rho phi.
Regards,
Daniel
danny123 is offline   Reply With Quote
Micro Scale Pore, icoFoam gooya_kabir OpenFOAM Running, Solving & CFD 2 November 2, 2013 13:58
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 15:33
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 bookie56 OpenFOAM Installation 8 August 13, 2011 04:03
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 02:58
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 18:07
