anuragm |
April 27, 2015 11:12 |
Error while using forAllIter macro in own equation file
1 Attachment(s)
I want to solve an additional set of equations in multiphaseEulerFoam for my case, so I made a new file called DQMOMEqns_New.H.
But when I compile, I get some errors:
DQMOMEqns_New.H: In function ‘int main(int, char**)’:
DQMOMEqns_New.H:42:43: error: ‘phases_’ was not declared in this scope
forAllIter(PtrDictionary<phaseModel>, phases_, iter)
/home/m/OpenFOAM/OpenFOAM-2.3.x/src/OpenFOAM/lnInclude/UList.H:443:37: note: in definition of macro ‘forAllIter’
Container::iterator iter = (container).begin(); \
In file included from multiphaseEulerPbeFoam.C:91:0:
DQMOMEqns_New.H:66:60: error: ‘phi1’ was not declared in this scope
surfaceScalarField phir[phasei](phase.phi() - phi1());
DQMOMEqns_New.H:66:61: error: variable-sized object ‘phir’ may not be initialized
DQMOMEqns_New.H:72:43: error: no matching function for call to ‘div(Foam::surfaceScalarField [(((sizetype)(((ssizetype)phasei) + -1)) + 1)], Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&)’
+ fvm::div(phir,weight[phasei])
I have attached this file with the post. I am also quoting the offending part of the code here:
int phasei = 0;
phaseModel& phase = iter();
volScalarField& alpha = phase;
if (phasei == 0)
surfaceScalarField phi1 = phase.phi();
sumAlpha = alpha;
phasei++;
Am I not using this macro correctly? Or is there something else that I have overlooked?
