sigSegv ERROR caused by SLPtrList<>
greetings to everyone.
your checking this thread has made me thankful. i now encounter a tough problem, which maybe C++ programming involved. i develop mySolver in OF-2.3.0 on ubuntu-12.04 and everything seems to be OK. it can run normally and give the expected results. however, problem comes with the last statement of the main function, "return 0". here is all what i get: Code:
#0 Foam::error::printStack(Foam::Ostream&) in "/home/yk/OpenFOAM/OpenFOAM-2.3.0/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" any idea will make my day. thanks for the attention. best regards, jhyk |
some struggling...the problem is addressed but not solved.
it comes from the SLPtrList<> (in src/OpenFOAM/containers/LinkedLists/user/SLPtrList.H), which unfortunately i know nothing about. when debugging with gdb, i find that a class containing an object of SLPtrList<> could not destruct normally. i think this is the problem makes the program could not return 0. so, could someone kindly say something about this confusing SLPtrList<>? or where i can learn more about it? any idea will be greatly appreciated! |
Greetings,
I guess I'm too late to answer now, but in theory:
Best regards, Bruno |
Hello @cfdopenfoam
Were you able to discover what the problem is? Best regards |
