Read a new variable from a solver to turbulence model
Dear Foamers,
I've added the equation of state in the pisoFoam solver, now the rho is a function of temperature and salinity. The solver works well and the rho can be updated at every time step. rho==1000; rho==(rho/1000*(999.842594+6.793952e-2*T-(9.095290e-3*pow(T,2))+(1.001685e-4*pow(T,3))-(1.120083e-6*pow(T,4))+(6.536336e-9*pow(T,5))+S*(8.24493e-1-4.0899e-3*T+(7.6438e-5*pow(T,2))-(8.2467e-7*pow(T,3))+(5.3875e-9*pow(T,4)))+(pow(S,1.5))*(-5.72466e-3+1.0227e-4*T-1.6546e-6*pow(T,2))+S*(4.8314e-4))); Currently I'm trying to add this rho into the incompressible kEpsilon turbulence model, rho_ ( IOobject ( "rho", runTime_.timeName(), mesh_, IOobject::READ_IF_PRESENT, IOobject::AUTO_WRITE ), mesh_ ), however the model just reads the initial rho instead of the updated rho, I find it hard to read a new variable from a solver to a turbulence model. Can anybody drop a hint? Thanks in advance. Regards, Clark |
What you need is the lookup command it is mainly used for this stuff (fetch a variable from the solver into a model in the library) You can see a simple example in the following link: http://www.tfd.chalmers.se/~hani/kur...nFoam%20v2.pdf page 11 where he needed the variable T to go into his viscosity model using: const volScalarField& T= U_.mesh().lookupObject<volScalarField>("T"); Hope that helps |
Hi Ali,
Thanks, I believe it's a good way, however, I haven't figured out where to put it in the incompressible kEpsilon model. I have written the following one: const volScalarField& rho= U_.mesh().lookupObject<volScalarField>("rho"); If I put it before the "namespace", an error called "'volScalarField' does not name a type" shows up, as expected. If I put it after the "namespace" but before "Constructors", an error called "‘U_’ was not declared in this scope" shows up; If I put it within the "kEpsilon::kEpsilon" and after "const word& modelName,", an error called "‘prototype for ‘Foam::incompressible::RASModels::kEpsilon::kEpsil on(const volVectorField&, const surfaceScalarField&, Foam::transportModel&, const Foam::word&, const Foam::word&, const volScalarField&)’ does not match any in class ‘Foam::incompressible::RASModels::kEpsilon’" shows up; If I put it after the "Constructors" but before "Member Function", the error called "‘U_’ was not declared in this scope" shows up again; If I put it within the "void kEpsilonGGDH::correct()", an error called "‘ invalid initialization of reference of type ‘const volScalarField&" shows up. Any help is appreciated. Thanks Clark |
im not 100% sure
but i would see it should go in: tmp<fvVectorMatrix> kEpsilon::divDevRhoReff ( const volScalarField& rho, put me here volVectorField& U ) const { volScalarField muEff("muEff", rho*nuEff()); return ( - fvm::laplacian(muEff, U) - fvc::div(muEff*dev(T(fvc::grad(U)))) ); } |
Hi Ali,
Thank you for your help! It works very well now! Finally I put it within "void kEpsilon::correct()" Thanks again, Clark |
