How to access to the solid body motion state from a custom interDyMFoam.C ?
Like Tree4Likes
  • 3 Post By jmf
  • 1 Post By yuhan1991
Old   June 24, 2015, 16:07
Default How to access to the solid body motion state from a custom interDyMFoam.C ?
jmf
Jean-Michel FONTAINE
jmf is on a distinguished road
Hi every body
I'm stuck on this coding problem since weeks
My target is to expose the solid body motion caracteristics to the solver, for instance v() or a().
I tried many ways, without success. Here is the current state of my attempts.
The idea is to expose motionPtr_ via a public function.
This is the modified dynamicMotionSolverFvMesh.H :
#ifndef dynamicMotionSolverFvMesh_H
#define dynamicMotionSolverFvMesh_H
#include "dynamicFvMesh.H"
namespace Foam
class motionSolver;
class dynamicMotionSolverFvMesh: public dynamicFvMesh
    // Private data
    autoPtr<motionSolver> motionPtr_;
    // Private Member Functions
    //- Disallow default bitwise copy construct
    dynamicMotionSolverFvMesh(const dynamicMotionSolverFvMesh&);
    //- Disallow default bitwise assignment
    void operator=(const dynamicMotionSolverFvMesh&);
public:
    //- Runtime type information
    TypeName("dynamicMotionSolverFvMesh");
    // Constructors
        //- Construct from IOobject
        dynamicMotionSolverFvMesh(const IOobject& io);
    //- Destructor
    ~dynamicMotionSolverFvMesh();
    // Member Functions
        //- Update the mesh for both mesh motion and topology change
        virtual bool update();
        // this is the additionnal public function <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
        Foam::motionSolver* motionSolverPtr() { return motionPtr_.ptr(); };
#endif
This is myInterDyMFoam.C:
Application
    interDyMFoam
#include "fvCFD.H"
#include "CMULES.H"
#include "subCycle.H"
#include "immiscibleIncompressibleTwoPhaseMixture.H"
#include "turbulenceModel.H"
#include "pimpleControl.H"
#include "fvIOoptionList.H"
#include "fixedFluxPressureFvPatchScalarField.H"
#include "dynamicMotionSolverFvMesh.H" // <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
int main(int argc, char *argv[])
    #include "setRootCase.H"
    #include "createTime.H"
    #include "createDynamicFvMesh.H"
    #include "initContinuityErrs.H"
    // this is the attempt to call motionSolverPtr() <<<<<<<<<<<<<<<<<<<<<<<
    Foam::motionSolver* motionPtr; //<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
    motionPtr = Foam::dynamicMotionSolverFvMesh::motionSolverPtr(); //<<<<<<
    Info<< "motionPtr->v() = " << motionPtr->v() << nl << endl; //<<<<<<<<<<
    pimpleControl pimple(mesh);
    #include "createFields.H"
    #include "readTimeControls.H"
    #include "createPrghCorrTypes.H"
    volScalarField rAU
        IOobject
            "rAU",
            runTime.timeName(),
            mesh,
            IOobject::READ_IF_PRESENT,
            IOobject::AUTO_WRITE
        mesh,
        dimensionedScalar("rAUf", dimTime/rho.dimensions(), 1.0)
    #include "correctPhi.H"
    #include "createUf.H"
    #include "CourantNo.H"
    #include "setInitialDeltaT.H"
    Info<< "\nStarting time loop\n" << endl;
    while (runTime.run())
        #include "readControls.H"
        #include "alphaCourantNo.H"
        #include "setDeltaT.H"
        runTime++;
        Info<< "Time = " << runTime.timeName() << nl << endl;
        // --- Pressure-velocity PIMPLE corrector loop
        while (pimple.loop())
            if (pimple.firstIter() || moveMeshOuterCorrectors)
                scalar timeBeforeMeshUpdate = runTime.elapsedCpuTime();
                mesh.update();
                if (mesh.changing())
                    Info<< "Execution time for mesh.update() = "
                        << runTime.elapsedCpuTime() - timeBeforeMeshUpdate
                        << " s" << endl;
                    gh = g & mesh.C();
                    ghf = g & mesh.Cf();
                if (mesh.changing() && correctPhi)
                    // Calculate absolute flux from the mapped surface velocity
                    phi = mesh.Sf() & Uf;
                    // Make the flux relative to the mesh motion
                    fvc::makeRelative(phi, U);
                    mixture.correct();
                if (mesh.changing() && checkMeshCourantNo)
                    #include "meshCourantNo.H"
            #include "alphaControls.H"
            #include "alphaEqnSubCycle.H"
            mixture.correct();
            #include "UEqn.H"
            // --- Pressure corrector loop
            while (pimple.correct())
                #include "pEqn.H"
            if (pimple.turbCorr())
                turbulence->correct();
        runTime.write();
        Info<< "ExecutionTime = " << runTime.elapsedCpuTime() << " s"
            << "  ClockTime = " << runTime.elapsedClockTime() << " s"
            << nl << endl;
    Info<< "End\n" << endl;
    return 0;
Result : this does not compile. The compilation error are :
interDyMFoam.C: In function ‘int main(int, char**)’:
interDyMFoam.C:57:17: error: ‘motionSolverPtr’ is not a member of ‘Foam::dynamicMotionSolverFvMesh’
interDyMFoam.C:58:54: error: invalid use of incomplete type ‘class Foam::motionSolver’
In file included from interDyMFoam.C:44:0:
/home/nous/OpenFOAM/OpenFOAM-2.3.x/src/dynamicFvMesh/lnInclude/dynamicMotionSolverFvMesh.H:45:7: error: forward declaration of ‘class Foam::motionSolver’
I can't find a solution, I don't understand this.
And furthermore the next question is : would motionPtr->v() give something ?
I would appreciate any help
Best regards
Jean-Michel
jmf is offline   Reply With Quote
Old   November 19, 2016, 07:09
Default [Solved] How to access to the solid body motion state from interDyMFoam.C ?
jmf
Hi
The solution for me was to use dictionaries in the object registry. Some example here after.
Create the dictionary and write something:
   /* interDyMFoam.C
    // Creates the exchange dictionary in the registry
    dictionary dataDict;
    mesh.thisDb().store
        new IOdictionary
            IOobject
                "motion",
                runTime.timeName(),
                mesh,
                IOobject::NO_READ,
            dataDict
   // Open and write
    const dictionary& motionDict =
            mesh.thisDb().lookupObject<IOdictionary>("motion");
    // Update for the motion solver
    dictionary updateDbDictionary = &motionDict;
    updateDbDictionary.set("centreOfRotation", initalCentreOfMass_);
    const_cast<dictionary& > (motionDict) = updateDbDictionary ;
Read something:
/* sixDoFRigidBodyMotionSolver.C
    if ( mesh().thisDb().foundObject<IOdictionary >("motion"))
        const dictionary& dbDictionary =
                  mesh().thisDb().lookupObject <IOdictionary >("motion");
        point centreOfRotation
            = dbDictionary.lookupOrDefault("centreOfRotation", point(0, 0, 0));
This works everywhere one has access to mesh or time.
The const_cast trick allows overwriting everywhere. It come from the post #14 of this thread:
http://www.cfd-online.com/Forums/ope...rfield-bc.html
Without an access to time or mesh, for instance in sixDoFRigidBodyMotion.C, I did not found better solution than adding setter and getter functions, which is hassle. It a pity that not all the classes have access to registry.
Hope this will be useful
Jean-Michel
zkdkeen, yuhan1991 and wdx_cfd like this.
Old   February 23, 2017, 07:33
Yu Han
yuhan1991 is on a distinguished road
Hi! Thank you for your contribution,I also need to get the solid body motion state in the main Foam-solver to calculate the quaternion . But I didn't make it work when I did what you say.Could you please help me?
I added the following code into myinterDyMFoam.C:
#include "sixDoFRigidBodyMotion.H"
    mesh.thisDb().store
        new IOdictionary
            IOobject
                "motion",
                runTime.timeName(),
                mesh,
                IOobject::NO_READ,
            dataDict
   // Open and write
But the compiler said that:
error: ‘initialCentreOfMass_’ was not declared in this scope
     updateDbDictionary.set("centreOfRotation", initialCentreOfMass_);
make: *** [Make/linux64GccDPInt32Opt/myinterDyMFoam.o] Error 1
I also put the second part of codes into sixDoFRigidBodyMotionStateIO.C(in void Foam::sixDoFRigidBodyMotionState::write(Ostream& os) const ,because I thought that the motion state would be exported with the sixDoFRigidBodyMotionState )
    os.writeKeyword("centreOfRotation")
        << centreOfRotation_ << token::END_STATEMENT << nl;
    os.writeKeyword("orientation")
        << Q_ << token::END_STATEMENT << nl;
    os.writeKeyword("velocity")
        << v_ << token::END_STATEMENT << nl;
    os.writeKeyword("acceleration")
        << a_ << token::END_STATEMENT << nl;
    os.writeKeyword("angularMomentum")
        << pi_ << token::END_STATEMENT << nl;
    os.writeKeyword("torque")
        << tau_ << token::END_STATEMENT << nl;
But the compile didn’t pass either.The compiler gave another information:
sixDoFRigidBodyMotion/sixDoFRigidBodyMotionStateIO.C:59:15: error: ‘mesh’ was not declared in this scope
sixDoFRigidBodyMotion/sixDoFRigidBodyMotionStateIO.C:59:38: error: ‘IOdictionary’ was not declared in this scope
The version of OpenFOAM is 3.0.1. Could you please give me some advice? I would appreciate any help. Thank you very much.
yuhan1991 is offline   Reply With Quote
Old   February 25, 2017, 12:23
Default How to access to the solid body motion state from interDyMFoam.C
jmf
Hi
First you have to declare and initialize initialCentreOfMass_, possibly from dynamicMeshDict, like this :
IOdictionary dynamicMeshDict (
        IOobject (
            "dynamicMeshDict",
            runTime.constant(),
            mesh,
            IOobject::MUST_READ,
            IOobject::NO_WRITE
    dictionary subDict = dynamicMeshDict.subDict("tightBodyMotionCoeffs");
    vector initalCentreOfMass_ = subDict.lookup("centreOfMass");
I never tried to use sixDoFRigidBodyMotionState.
But I'm afraid that like sixDoFRigidBodyMotion, sixDoFRigidBodyMotionStateIO doesnt have any access to mesh(), mesh, neither to time or time(), which carry the registry.
If you really need to exchange data with them, a inelegant way is to write setter and getter methods in sixDoFRigidBodyMotionStateIO.C. Here is an example you will have to adapt to your needs :
void Foam::sixDoFRigidBodyMotion::set_v0(Foam::vector v) { v0_ = v;}
Foam::vector Foam::sixDoFRigidBodyMotion::get_v0() { return v0_;}
Good luck
Jean-Michel
Old   March 6, 2017, 09:07
Yu Han
Hi Fontaine! Thank you for your help again! Recently I have already made this work successfully . Now I can get the 6dof motion of the body from sixDofRigidBodyDisplacementPointPatchVectorField:: updateCoeffs() and write them to a dictionary in the main solver . So you can use them anywhere while the program is running(but the user must be able to access the object registry).This is the code snippet in the main solver:
        runTime.store
        new IOdictionary
            IOobject
                "motion",
                runTime.timeName(),
                runTime,
                IOobject::NO_READ,
            dataDict
    const dictionary& dbDictionary = runTime.lookupObject <IOdictionary >("motion");
    Info <<"Get centreOfRotation from database:"<< dbDictionary.lookupOrDefault("centreOfRotation", point(0, 0, 0)) <<endl;
    Info <<"Get initialCentreOfRotation from database:"<< dbDictionary.lookupOrDefault("initialCentreOfRotation", point(0, 0, 0)) <<endl;
    Info <<"Get orientation from database:"<< dbDictionary.lookupOrDefault("orientation", tensor(0, 0, 0, 0, 0, 0, 0, 0, 0)) <<endl;
    Info <<"Get initialOrientation from database:"<< dbDictionary.lookupOrDefault("initialOrientation", tensor(0, 0, 0, 0, 0, 0, 0, 0, 0)) <<endl;
This is the modified sixDoFRigidBodyDisplacementPointPatchVectorField.C :
void sixDoFRigidBodyDisplacementPointPatchVectorField::updateCoeffs()
 if ( t.foundObject<IOdictionary >("motion"))
       t.lookupObject<IOdictionary>("motion");
       updateDbDictionary.set("centreOfRotation", motion_.state().centreOfRotation());
       updateDbDictionary.set("initialCentreOfRotation", motion_.getinitialCentreOfRotation());
       updateDbDictionary.set("orientation", motion_.orientation());
       updateDbDictionary.set("initialOrientation", motion_.getinitialQ());
       const_cast<dictionary& > (motionDict) = updateDbDictionary ;  //without this code the result will still be ZERO!!!
I hope this is useful.
Thank you for you help again Fontaine !
zkdkeen likes this.
Old   February 26, 2019, 20:45
Dongxu Wang
wdx_cfd is on a distinguished road
Originally Posted by jmf View Post
Hi
        IOobject (
            "dynamicMeshDict",
            runTime.constant(),
            mesh,
            IOobject::NO_WRITE
Good luck
Jean-Michel
Hi Jean-Michel,
I am facing a very similar problem recently. I have accessed the motion state by your method and I want to use it as a judgement of the stop of the PIMPLE outer loop.
For example:
I change the code:
while(pimple.loop())
/*  pimpleloop */
to
while(true)
/*  pimpleloop */
if(condition)         // condition is the parameter of rigid body that
{                        // calculated in sixDOFSolver and obtained from
    break;            // your method. In other words, the pimple outer
}                        // loop will stop if the condition becomes true.
This code has no problem when running in the serial model. However, an error occurs once the program ran parallel. The erroe is just like this:
[1] --> FOAM FATAL IO ERROR:
[1] error in IOstream "IOstream" for operation operator>>(Istream&, List<T>&) : reading first token
[1]
[1] file: IOstream at line 0.
[1]
[1]     From function void Foam::IOstream::fatalCheck(const char*) const
[1]     in file db/IOstreams/IOstreams/IOstream.C at line 109.
[1]
FOAM parallel run exiting
It seems that there is a problem of the IOstream which maybe due to the dictionary we define in the interFoam. This error appears when the first time step is finished(i.e. break by the "condition" obtained from sixDOFSolver). Furthermore, it happens at the moment of accessing the primitiveField when calculating the courant number:
fvc::surfaceSum(mag(phi))().primitiveField()
There is a problem of reading the internal field. I am using openfoam v6 and this problem makes me confused. Would you please give me some suggestions? Thank you very much!
wdx
wdx_cfd is offline   Reply With Quote
Old   March 2, 2019, 09:04
Default Works in serial mode, and not in paralle
jmf
Hi
In parallel each processor do its own job, ignoring the existence of the other procs. You have to ensure the consistency of the data that are used for your stop condition, and after that, to publish the condition to all the processors at the same time.
So you may be interested in functions like this, to build your condition and publish it :
if (Pstream::master())
    x = 1;
Pout<< x << endl;
Pstream::scatter(x);
Pout<< x << endl;
See also in forces.C ways to gather the data from all procs:
Pstream::listCombineGather(force_, plusEqOp<vectorField>());
Hope it helps
J-Michel
Old   March 3, 2019, 21:17
Dongxu Wang
Hi
    x = 1;
Pout<< x << endl;
Pout<< x << endl;
Hope it helps
J-Michel
Hi Michel,
Thank you for your advice!
I will try it recently and I will publish the result here.
Thanks a lot.
wdx.
Old   September 19, 2019, 20:59
Zhi Cheng is on a distinguished road
Hi,yuhan! I don't know if you could get this message after long time. I am using your method, but the output was always zero. I found maybe my "motion" in my dyfoamsolver is not connected to the "motion" in sixDoFRigidBodyDisplacementPointPatchVectorField.C . Because if I change "motion" to "motion1" in my solver, it also compile. Do anyone knows why?
Best regards,
ZHI CHENG
        runTime.store
        new IOdictionary
            IOobject
                "motion",
                runTime.timeName(),
                runTime,
                IOobject::NO_READ,
            dataDict
Zhi Cheng is offline   Reply With Quote
Old   January 29, 2022, 19:31
TWB
quarkz is on a distinguished road
        runTime.store
        new IOdictionary
            IOobject
                "motion",
                runTime.timeName(),
                runTime,
                IOobject::NO_READ,
            dataDict
Hi, I need to get the orientation (pitch) of the body in my 6dof problem at each time step. I then want this info in my modified oscillatingDisplacement mesh routine. Is it possible? If so, I need some help understanding this. I'm using overPimpleFoam.
So do I add this:
        runTime.store
        new IOdictionary
            IOobject
                "motion",
                runTime.timeName(),
                runTime,
                IOobject::NO_READ,
            dataDict
into the end of overPimpleFoam.c ? if not, where do i add them?
And also add:
into sixDoFRigidBodyDisplacementPointPatchVectorField.C ?
Lastly, how can i access the orientatio tensor from my modified oscillatingDisplacement mesh routine?
Sorry, I am a Fortran programmer so my knowledge of c++ is limited. Thanks for the help.
quarkz is offline   Reply With Quote
custom solver, motion, state
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 06:27
[DesignModeler] Question about converting surface body to solid body in DesignModeler lnk ANSYS Meshing & Geometry 2 November 24, 2013 00:02
[DesignModeler] how to subtract a surface body from a solid body? yahya ANSYS Meshing & Geometry 4 January 7, 2013 11:00
cooling a solid body Ralf Schmidt FLUENT 1 April 16, 2007 10:54
