Actuator Disk Implementation Problem
Hi All,
I am trying to follow a report that was about the "Actuator Disk Method". It is an interesting topic to learn. I have read the report until page 7, and then I have tried to apply what is been done in the report. However, I have faced some difficulties match it to OpenFoam 2.3.2 since it was made in the old version 1.5. I am asking if anybody of you by any chance run through the steps and find sometime to help out in this regard. http://www.tfd.chalmers.se/~hani/kur...ningReport.pdf Here is "the error"what I got when I ran blockMesh and simpleFoam: "--> FOAM FATAL IO ERROR: Cannot find patchField entry for cyclic fan_half0 Is your field uptodate with split cyclics? Run foamUpgradeCyclics to convert mesh and fields to split cyclics. file: /home/tariq/windturbine/project3/erikSvenningFiles/fan/0/p.boundaryField from line 34 to line 59. From function GeometricField<Type, PatchField, GeoMesh>::GeometricBoundaryField::readField(const DimensionedField<Type, GeoMesh>&, const dictionary&) in file /home/tariq/OpenFOAM/OpenFOAM-2.3.1/src/OpenFOAM/lnInclude/GeometricBoundaryField.C at line 192. FOAM exiting " Thank you in advance |
