Rotating motion
Can someone please tell me how I can modify rotating Motion sub class in Solid Body Motion Functions, in order to use a calculated rotational speed instead of a constant rotational speed? I am simulating a wind driven turbine. So rotation should be wind induced rather than predefined. I indent to do this as follows.
Can some one tell me how to use calculated values from a solver as inputs to a solid body motion function. Thanks kcn |
I have programmed a speed ramp of an impeller in the past. You will propably find in one of those posts. OpenFoam uses the time to determine the current rotation angle. At contant angle speed this is a linear function, but this can be changed in the dynamic mesh class you have to build. The mesh movement then is simply called by the mesh.update. However, for your purpose, you will need the angle acceleration too, as well as delta T. So, I would follow the definition of time (duration) in the dynamic mesh class and define the new entities that you need. Regards, Daniel |
Dear Daniels,
Thanks a lot for your reply, I looked at your earlier post. Once the acceleration is obtained I can use a similar way to incorporate variable rotation speed. However in my case acceleration is flow induced in following way. Acceleration = flow induced torque/Moment of inertia I made a new class based on SolidBodyMotionFvMesh which I named windMotionFvMesh. Torque is calculated by the solver during run time. My problem is, how can I communicate this torque value to windMotionFvMesh? I tried updating the dynamicMeshDict during rum time. So that during each iteration torque can be read from there. But it didn't work. It seems solidBodyMotionFvMesh do not read dynamicMeshDict during each iteration. Is there any way I can directly communicate torque value to windMotionFvMesh? |
Hello kcn,
The moment of inertia should be a constant unless the geometry of your impeller changes, agreed? Then, what you need is instead of angle of rotation = f(t) (as it is implemented in OpenFoam now): angle of rotation new = angle of rotation old + rotation speed old x deltaT + deltaT^2 x Torque/(Moment of Inertia). So, instead of time you propably have to pass the angle directly to your new dynamic mesh class. So, I would suggest you to look where the current class gets the time value from and add another variable to pass (which then is the angle). You could also "missuse" the time variable by setting it to the angle value, do a mesh update and setting it back. But this is "dirty" programming trick and I would not recommend it. Regards, Daniel |
Dear Daniel,
Time is directly passed as runTime. I tried following code that others have used to access field values (p & U) form boundary condition classes. This was also used in post processing class "forces" to access velocity fields. const volTypeField& X = db().objectRegistry::lookupObject<volTypeField>("X "); How ever I get the following error " ‘db’ was not declared in this scope" Thanks, kcn |
It compiled when I replaced the RHS with time_.lookupObject<volTypeField>("X") |
The runTime objects are defined in time.C and time.H. You can define a new entity called e.g. "angle" similar to deltaT. This angle then can be changed by a set procedure (similar to setdeltaT).
You then need to define an object that can be called within the dynamic mesh object. In this example, it should be similar to runTime.deltaTValue(). The angle then can be set using the torque balance in your application solver. After the mesh.update() it should then appear in your dynamic mesh object.:) I do not know how to get the forces on the shaft, since I always only see the result table only. Maybe somebody else can help you on that one.:confused: Regards, Daniel |
Can anyone successfully implement the wind induced velocity change?
Time variation in the rotation
I dont know if this helps, but to allow for a time variation in the rotation, I have
done the following in OF 2.3.1. (should be similar with other versions) cd $HOME/OpenFOAM/OpenFOAM-2.3.1/src/dynamicFvMesh/solidBodyMotionFvMesh/solidBodyMotionFunctions/ cd rotatingMotion gedit rotatingMotion.C in the function (line 73) Foam::septernion Foam::solidBodyMotionFunctions::rotatingMotion::tr ansformation() const you can do your stuff I added ... const scalar PI = constant::mathematical::pi; // scalar angle = omega_->integrate(0, t); scalar angle = Foam::sin(1.0*PI*t)*omega_->integrate(0, t); Now you have sinus type of rotation. You can add other functions, like atan if you want a steady increase and then steady state rotation. --------------------------------------------------------------------------- In ./constant/dynamicMeshDict dynamicFvMesh solidBodyMotionFvMesh; solidBodyMotionFvMeshCoeffs { cellZone none; // none => the whole mesh rotates. // if you want only part of it to rotate, you have to define // that region. see examples in openfoam wiki solidBodyMotionFunction rotatingMotion; rotatingMotionCoeffs { origin ( 0 0 0 ); axis ( 0 0 1 ); omega 1.4451; // rad/s // omega = 2*pi*(0.23 rps) } } |
It was a old thread.
But I want to ask something. why the term(1.0/constant::mathematical::pi*omega_) is added??? |
