Wrong operator in transonic pressure equation?
Like Tree2Likes
  • 2 Post By Horacio Aguerre
Old   June 6, 2011, 08:45
Post Wrong operator in transonic pressure equation?
Florian Ettner
dohnie is on a distinguished road
in my transonic simulations with reactingFoam my local continuity errors are far too high (~0.01).
I've stumbled upon the pressure equation: After the pEqn is solved, the flux is corrected. In the subsonic case:
        if (nonOrth == nNonOrthCorr)
            phi += pEqn.flux();
In the transonic case:
            phi == pEqn.flux();
Shouldn't the latter "==" operator be replaced by a "+=", too?
If not, who can explain it?
dohnie is offline   Reply With Quote
Old   July 10, 2015, 12:07
België/Belgique
David1 is on a distinguished road
I know I am replying on an old post, but have you found your answer?
I have a similar doubt with rhoSimpleFoam, where:
phi == pEqn.flux();
in the transonic case and:
phi -= pEqn.flux();
for subsonic flow
David1 is offline   Reply With Quote
Old   July 11, 2015, 22:16
Horacio Aguerre is on a distinguished road
Hello Florian,
Note that the method "flux()" is applied over the fvMatrix (pEqn). When solving with the transonic flag in true, the pEqn contains the advective term fvm::div(...). The whole continuity equation is assembled implicity in the pressure equation and then the flux can be calculated with pEqn.flux().
On the other hand, in subsonic cases the advective term is assembled eplicity with fvc::div(phi(or phiHByA)). The last term is not in the pEqn matrix (l.h.s part) and then the advective term must be taken in account to construct the phi flux as phi = phi + pEqn.flux() or phi = phiHByA + pEqn.flux()
hope it helps!
hjasak and David1 like this.
Horacio Aguerre is offline   Reply With Quote
coupling, flux correction, transonic
Pressure work term in turbulent K.E. equation lost.identity Main CFD Forum 0 March 8, 2011 12:21
Strcture of pressure correction equation in PISO stable over time ? sebi Main CFD Forum 1 October 26, 2010 22:19
Constant velocity of the material Sas CFX 15 July 13, 2010 08:56
pressure Poisson equation in fractinoal step metho Rui Main CFD Forum 6 October 15, 2000 04:57
Hydrostatic pressure in 2-phase flow modeling (long) DS & HB Main CFD Forum 0 January 8, 2000 15:00
