August 14, 2015, 09:46 |
Energy equation
Shovan
Rep Power: 10 |
May i know in which Openfoam solver will i get the following equation: Why different solvers using navier stroke's equation have different momentum and energy equations? The navier stroke's equation should be same for all solvers right? |
August 17, 2015, 08:46 |
Rep Power: 18 |
Equations may differ because a different energy is used. For example some use inner energy while others use enthalpy. Also, some solvers are compressible while others are incompressible.
August 18, 2015, 01:58 |
Shovan
Rep Power: 10 |
Thanks can you tell me in which solver of openfoam will i get the above mentioned energy equation.
regards Shovan Kumar Sahu |
August 18, 2015, 02:20 |
Matvey Kraposhin
Rep Power: 21 |
reactingFoam can be the nearest choice, but without term #2 in RHS (sum h_j J_j)
But, if you will solve energy in enthalpies and assume Le number equal to 1, then term #2 in RHS will become compensated by enthalpy diffusion term Last edited by mkraposhin; August 18, 2015 at 03:36. Reason: english grammar |
August 18, 2015, 02:39 |
Shovan
Rep Power: 10 |
Thank you all
modify a solver to account for energy equation. | Yanci | OpenFOAM Running, Solving & CFD | 0 | November 11, 2014 09:23 |
Energy equation issue | zytra | FLUENT | 0 | October 20, 2014 21:34 |
Need experience comment on cavitation combine energy equation!!! | lehoanganh07 | FLUENT | 0 | September 24, 2014 10:28 |
Energy equation in OpenFoam | nwpukaka | OpenFOAM Programming & Development | 2 | June 24, 2014 02:40 |
SIMPLE and energy equation convergence | Fabio | Main CFD Forum | 0 | June 1, 2007 06:06 |
