from UDF(fluent) to OpenFOAM code
Hi everybody,
i've to use the following UDF in an OpenFOAM case. I know that OF doesn't use UDF but I don't know how implement the code in OF. The UDF is used to evaluate the source term of a heat exchange. Code:
#include "udf.h" Regards Francesco |
Hello Francesc,
In OpenFOAM terms, you can check fvOptions. It allows you to add a source term to the solver governing equations as a part of case setup. Search here in the forum for fvOptions. Check this [LINK] as an example but I believe it is not the only one. Best wishes, Hassan |
