Add a source term into a openfoam Solver
I am going to use a non inertial reference frame for the fluid. In that case I have to add the acceleration of the frame into the Navier Stokes equations. Acceleration is uniform across the fluid and time varying. I am going to threat it as a force term. I know how to updates the boundary condition, but I don't know how to update the internal field. Can you please give your ideas and references. Thank you Methma |
Actually I could do it.
The acceleration of the frame was defined as a field variable "ddy", I gave fixed value boundary condition for all boundaries. I updated the internal field by Code:
ddy = dimensionedVector("myddy", dimAcceleration, vector(0,sddy,0)); best, Methma |
i see you have solved your problem. I also want to add a acceleration into NS equation. But without any experience. Actually, I wanna use a horizontal acceleration replace moving dynamic mesh to excite fluid movement in a tank. Do you have any advise about that ? thx jinheng |
