Fade-in fvOptions source
Dear Foamers,
I would like to fade in a custom-made source term during the progress of the simulation. The momentum source is introduced with a new fvOptions-class. I tried the following (for simpleFoam first): The variable 'time' gives the time of the simulation and the variable 'factor' should be used to fade in the source term (after the fvOptions is switched to active after 100 iterations). Code:
const Time& time = mesh().time(); Questions: - 1) Is there a better approach? - 2) Should I 'convert' the 'Time'-type to sth. else? Regards, Peter |
You might want to read the following thread regarding your question #2: http://www.cfd-online.com/Forums/ope...me-scalar.html Best regards, Fumiya |
Dear Fumiya,
Thanks a lot!! |
