Thermophysical transport model to include shear rate
Greetings!
I'm currently working on new thermophysical model with its own equation of state and transport properties. I get stuck when I try to implement shear rate dependence of viscosity. Is this feasible? Where would you calculate shear rate and pass it to viscosity function? Goal is to capture shear thinning behaviour of polymers with multiphase flow. This is where ("/src/thermophysicalModels/specie/transport/crossWLF/crossWLFTransportI.H") viscosity is evaluated. It takes p and T. Code:
template<class Thermo> Code:
template<class BasicPsiThermo, class MixtureType> |
Hi Janez,
Were you able to implement this modification? Thanks |
Hello sir,
yes we managed, source code can be downloaded: https://github.com/krebeljk/openInjMoldSim Regards, Janez Turk |
Is there a way to create a new thermomodel without having to modify the solver to reference it? I'm trying to create a modified version of heSolidThermo but cant see a way round modifying the solvers to reference a new version solidThermo as well
