Kinematic cloud properies the meainig of the terms
Old   February 23, 2016, 07:29
Default Kinematic cloud properies the meainig of the terms
Manu Chakkingal
manuc is on a distinguished road
Hello
I am trying to simulate bubble column with a combination of interfoam and kinematic cloud parcels (for bubble parcels).
I came across the properties
model1
type patchInjection;
massFlowRate .000072;
massTotal .0072;//
SOI 0;
nParticle 10; //is this the no. of particles in a parcel
parcelBasisType fixed;
patchName inlet;
parcelsPerSecond 1e2;
duration 20;
U0 (0 2 0);//is this the velocity of parcels at inlet
flowRateProfile constant 1;
sizeDistribution
type RosinRammler;
RosinRammlerDistribution
minValue 5e-3;
maxValue 5e-3;
d 5e-3;
n 3;
How is the mass flow rate determined for the parcels injected. What is the density used for calculation of the mass flow rate. is the volume flow rate (before multiplication with density to calculate mass flow rate) determined by using the velocity U0 in the above list times the area of inlet patch..Then what is the role of the diameter of particles specified in the distribution.
manuc is offline   Reply With Quote
Error during reconstructing lagarangian fields ybapat OpenFOAM 9 November 17, 2014 07:52
problem with solving lagrange reaction cloud Polli OpenFOAM Running, Solving & CFD 0 April 30, 2014 07:53
Running OpenFoam on a Computer Cluster in the Cloud - cloudnumbers.com Markus Schmidberger OpenFOAM Announcements from Other Sources 0 July 26, 2011 08:18
Question in definition of terms in solve titio OpenFOAM Running, Solving & CFD 0 March 19, 2009 16:02
K-Epsilon model? Brindaban Ghosh Main CFD Forum 2 June 24, 2000 04:22
