February 24, 2016, 02:04 |
Memory consumption of an IOobject
Dongyue Li
Rep Power: 17 |
Hi guys,
I have a confusion, for example, I have 100 same volScalarField, T1, T2, ... T100. I can create them by: Code:
volScalarField T1 ( IOobject ( "T1", runTime.timeName(), mesh, IOobject::NO_READ, IOobject::NO_WRITE ), mesh, dimensionedScalar("zero", dimensionSet(0, 0, 1, 0, 0), 0.0) ); Code:
volScalarField T2(T1); volScalarField T3(T1); ... Best, /*******************************************/ Okay, I got it, even with the second method, T2 is also registered from objectRegistry implicitly.
My OpenFOAM algorithm website: http://dyfluid.com By far the largest Chinese CFD-based forum: http://www.cfd-china.com/category/6/openfoam We provide lots of clusters to Chinese customers, and we are considering to do business overseas: http://dyfluid.com/DMCmodel.html |
February 24, 2016, 10:08 |
Hassan Kassem
Rep Power: 17 |
You conclusion is right.
You are creating the same type using two different constructors. First one is more explicit and the second one is a typical copy constructor. Therefore all the copied instances are registered to the same mesh and have the same field size. |
viewfactors memory consumption | derekm | OpenFOAM Pre-Processing | 0 | April 26, 2015 17:53 |
Run-time memory allocation error | akalopsis | CFX | 0 | November 17, 2014 17:17 |
Lenovo C30 memory configuration and discussions with Lenovo | matthewe | Hardware | 3 | October 17, 2013 10:23 |
reconstructParMesh not working with an axisymetric case | francesco | OpenFOAM Bugs | 4 | May 8, 2009 05:49 |
CFX CPU time & real time | Nick Strantzias | CFX | 8 | July 23, 2006 17:50 |
