March 12, 2016, 10:51 |
PMM test in OpenFOAM
Thaw Tar
Hi everyone,
I want to do the simulation of planar motion mechanism (PMM) test for an autonomous underwater vehicle (AUV) using OpenFOAM. I want to simulate the flow field around AUV which is fully submerged (single phase flow) using PMM procedure. I want to give the forced oscillations of yaw motion to the AUV for certain periods to create the sine wave motion using dynamic mesh in OpenFOAM. I searched for it and found Ship Design Analysis (SDA) using solid body motion. But it has only roll, heave and pitch motions. Thus, I want to know whether I can use this technique, by changing the coordinate system of the AUV to create yaw motion instead of roll. I am also not clear about whether I can use SDA for single phase flows. Or do I need to re-create another SDA that has the capability of doing yaw motion by myself? I am not good at OpenFOAM programming. Thanks in advance, Thaw Tar |
February 14, 2022, 01:55 |
Shamjad
Hii Thaw Tar..
Am also working on the same problem. were you able to solve this |
dynamic mesh, openfoam, ship design analysis |
Getting Started with OpenFOAM | wyldckat | OpenFOAM | 25 | August 14, 2022 13:55 |
OpenFOAM v3.0.1 Training, London, Houston, Berlin, Jan-Mar 2016 | cfd.direct | OpenFOAM Announcements from Other Sources | 0 | January 5, 2016 03:18 |
Cross-compiling OpenFOAM 1.7.0 on Linux for Windows 32 and 64bits with Mingw-w64 | wyldckat | OpenFOAM Announcements from Other Sources | 3 | September 8, 2010 06:25 |
Modified OpenFOAM Forum Structure and New Mailing-List | pete | Site News & Announcements | 0 | June 29, 2009 05:56 |
Cluster test with openfoam | clo | OpenFOAM Running, Solving & CFD | 7 | February 22, 2009 23:44 |
