Home > Forums > OpenFOAM Programming & Development
output lagrangian particle volume fraction "reactingParcelFoam"
Like Tree1Likes
  • 1 Post By jurich
Old   March 22, 2016, 09:11
Default output lagrangian particle volume fraction "reactingParcelFoam"
Bijan Darbari
bijan darbari is on a distinguished road
hello
I,m using "reactingParcelFoam" and I want to output volume fraction of lagrangian particles from this solver.
So I add these lines in the end of createfields.H and delete createcloud.H
Info<< "\nConstructing reacting cloud" << endl;
basicReactingMultiphaseCloud parcels
    "reactingCloud1",
    rho,
    U,
    g,
    slgThermo
volScalarField alphac
    IOobject
        "alphac",
        runTime.timeName(),
        mesh,
        IOobject::NO_READ,
        IOobject::AUTO_WRITE
    mesh,
    dimensionedScalar("0", dimless, 0)
alphac = max(1.0 - parcels.theta(), 0.01);
This solver compiled and run without any problem but:
1- If I solve the case with my modified solver. the output volume fraction (alphac) have uniform value "1" all over the domain. the output file is:
|  \\    /   O peration     | Version:  3.0.1                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       volScalarField;
    location    "5050";
    object      alphac;
dimensions      [0 0 0 0 0 0 0];
internalField   uniform 1;
boundaryField
    top
        type            calculated;
        value           uniform 1;
    bottom
        type            calculated;
        value           uniform 1;
    inlet
        type            calculated;
        value           uniform 1;
    outlet
        type            calculated;
        value           uniform 1;
    frontAndBack
        type            empty;
2- If I first solve the case with original "reactingParcelFoam" and after a one output write, solve with my modified solver. the output volume fraction file have real and true value and it is:
FoamFile
    version     2.0;
    format      ascii;
    location    "8050";
    object      alphac;
internalField   nonuniform List<scalar>
4000
0.9664896784
0.9413569371
0.979056049
0.9821976416
0.9958112098
0.9979056049
outlet
        type            calculated;
        value           nonuniform List<scalar>
40
1
1
0.9895280245
0.9623008882
0.9560177028
0.9539233077
0.9507817151
0.9497345175
0.9413569371
0.9560177028
0.9497345175
0.9539233077
0.9570649004
0.9591592955
0.939262542
0.9476401224
0.9549705053
0.9602064931
0.9476401224
0.958112098
0.9465929249
0.958112098
0.9424041347
0.939262542
0.9434513322
0.9591592955
0.9507817151
0.9413569371
0.9549705053
0.9455457273
0.9424041347
0.9507817151
0.9507817151
0.9350737518
0.9706784686
0.9444985298
0.9717256661
0.9874336294
1
1
    frontAndBack
        type            empty;
Is there any way to solve the case with my modified solver and output real value of lagrangian particles volume fraction?? ( like 2nd output )
What's the problem??
the modified solver attached.
the case uploaded to:
http://s000.tinyupload.com/index.php...81446598054142
thanks very much and excuse me for poor english.
Bijan.
bijan darbari is offline   Reply With Quote
Old   March 22, 2016, 11:23
Bijan Darbari
I run some cases and understand that my modified solver output lagrangian volume fraction from the last data writed by "reactionParcelFoam". and dont calculate the volume fraction from the present data.
how can I solve this problem??
Old   March 22, 2016, 22:35
Joseph Urich
jurich is on a distinguished road
Hello Bijan,
createFields.H is called only when reactingParcelFoam starts up. So your line alphac = max(1.0 - parcels.theta(), 0.01) is done one time, right after you initialize the parcels. So the parcels haven't been traced yet, and the call to theta() class returns zero.
Move alphac = max(1.0 - parcels.theta(), 0.01) to reactingParcelFoam.C, right after the call to parcels.evolve(). Then it will be done each time step.
bijan darbari likes this.
jurich is offline   Reply With Quote
Old   March 23, 2016, 05:21
Bijan Darbari
Hello jurich,
thank you very much and you,re right.
I,m do that and it,s working.
now my modified solver, outputing real lagrangian particles volume fraction at each time step.
Old   March 23, 2016, 16:22
Bijan Darbari
The modified solver attached.and working perfectly.
this modified solver outputs lagrangian particle volume fraction ( alphap ) and continuous phase volume fraction ( alphac ) at each time step.
also shows min/avg/max of this arrays on terminal when running case (for each time step).
Old   May 25, 2016, 02:19
Ping Chang
chpjz0391 is on a distinguished road
Hey bijian,
I am using the same solver now, do you know how to output the particles concentration(kg/m3) ?
Ping?
chpjz0391 is offline   Reply With Quote
Old   May 25, 2016, 02:44
Ping Chang
Originally Posted by chpjz0391 View Post
Hey bijian,
Ping?
I mean if I multiply rho directly? the solver will consider this rho to air flow's density. What should I do, do you have any suggestion?
Old   May 26, 2016, 00:42
Bijan Darbari
Dear chpjz0391
I don,t understand what you mean??
You can multiply particles density (kg/m3) to lagrangian particles concentration (m3/m3) and then you have ( kg/m3)
a much easier way for exporting lagrangian particles concentration:
paste these lines at the end of "reactingcloud1properties"
cloudFunctions
voidFraction
type voidFraction;
Old   May 26, 2016, 00:45
Ping Chang
Dear chpjz0391
cloudFunctions
voidFraction
type voidFraction;
Dear Bijan
Actually, I have already put the code under reactingcloud1properties, but I get no output for the voidFraction. Is the parameter which called reactingCloud1Theta stands for the volume fraction in paraview?
Regards
PIng
Old   May 26, 2016, 04:49
Ping Chang
Hi bijian,
Sorry to disturb you again. Firstly, thanks very much, voidFraction has worked. I used calculator function in paraview to multiply the particles density and got the concentration.
However, I have a another small question. I tried to output concentration directly by modifying the solver.
I add this code to my main function.
    while (simple.loop())
        Info<< "Time = " << runTime.timeName() << nl << endl;
        parcels.evolve();
        concen = parcels.rhoEff();
        Info<< "concen min/avg/max   = " << min(concen).value() << ", "
        << average(concen).value() << ", "<< max(concen).value() << endl;
And this in createFields.H
volScalarField concen
    IOobject
        "concen",
        runTime.timeName(),
        mesh,
        IOobject::NO_READ,
    mesh,
    dimensionedScalar("0", dimDensity, 0)
But is doesn't work .The concen is always zero.
Do you have any suggestion?
Regards,
Ping
Old   June 27, 2016, 07:15
Kabra is on a distinguished road
Hi all,
I actually have a very similar problem. I inject my particles using swak4foam and to get the theta-fields I wrote at the bottom of kinematicCloudProperties:
cloudFunctions {
voidFraction {
type voidFraction; }
Now I get a file called kinematicCloudTheta in the time folders, but it doesn't calculate anything as it always looks like this for each time-step:
|  \\    /   O peration     | Version:  2.3.0                                 |
FoamFile
    version     2.0;
    format      binary;
    location    "0.144001";
    object      kinematicCloudTheta;
internalField   uniform 0;
boundaryField
    leftWall
        type            calculated;
        value           uniform 0;
    rightWall
        type            calculated;
        value           uniform 0;
    outlet
        type            calculated;
        value           uniform 0;
    inlet
        type            calculated;
        value           uniform 0;
    front
        type            calculated;
        value           uniform 0;
    back
        type            calculated;
        value           uniform 0;
    probe
        type            calculated;
        value           uniform 0;
Does anyone have any suggestions?
Kabra is offline   Reply With Quote
Old   June 28, 2016, 01:09
Bijan Darbari
Dear Kabra
I think there is no particles in domain when you export "voidfraction". or particle injection didn't started.
Old   June 28, 2016, 02:54
Dear Bijan,
at this point there are several thousand particles in my domain. I also made sure that they are all active. Another case with freshly injected particles yields the same results. Additionally the particle diameter ist also > 0.
Old   June 28, 2016, 06:19
Bijan Darbari
Dear Kabra
Sorry. I don't have any idea.
- delete your "kinematiccloudteta" file in your case and run again.
- I use openfoam 3.0.1. and "reactingparcelfoam" solver. may be this is a bug in old versions.
Old   May 23, 2017, 09:36
Maria
marialhm is on a distinguished road
Originally Posted by Kabra View Post
Hi all,
cloudFunctions {
voidFraction {
FoamFile
    version     2.0;
    format      binary;
boundaryField
    leftWall
        type            calculated;
        value           uniform 0;
    rightWall
        type            calculated;
        value           uniform 0;
    outlet
        type            calculated;
        value           uniform 0;
    inlet
        type            calculated;
        value           uniform 0;
    front
        type            calculated;
        value           uniform 0;
    back
        type            calculated;
        value           uniform 0;
    probe
        type            calculated;
        value           uniform 0;
Dear Kabra,
Have you solved this problem? I have the same problem now.
Maria
marialhm is offline   Reply With Quote
Thread Tools
Trackbacks are On
alphaEqn.H in twoPhaseEulerFoam cheng1988sjtu OpenFOAM Bugs 15 May 1, 2016 16:12
how to set periodic boundary conditions Ganesh FLUENT 13 January 22, 2014 05:11
Difference between Volume Fraction and Mass Fraction in CEL foo7 CFX 0 September 21, 2011 08:45
On the damBreak4phaseFine cases paean OpenFOAM Running, Solving & CFD 0 November 14, 2008 22:14
