April 25, 2016, 04:55 |
Herschel Bulkley Papanastasiou model
Amith Gubbi
I am trying to simulate a herchel-bulkley model of blood through a 3D pipe and have implemented the Papanastasiou regularization. The model seems to work fine for nonNewtonianIcoFOAM(transient solver)but when i try to simulate it in a steady state solver(simpleFOAM), I get a floating point exception. I have attached the case setup with the log file and also the papanastasiou model that I have implemented. The Papanastasiou regularization is according to the following paper: http://www.bsr.org.uk/rheology-revie...-Mitsoulis.pdf Any suggestions regarding fixing this is appreciated. Thanks, Amith |
May 28, 2016, 07:29 |
Re:Herschel Bulkley Papanastasiou model Reply to Thread
Yaroslav
Rep Power: 12 |
I think some initial velocity distribution should set up. Like that: Code:
internalField uniform (0 0 1); residuals.png Uz.png I dont think that length of tube should be so big to find solution. I hope you found solution, please share it With best regards, Yaroslav |
March 2, 2017, 09:24 |
Emery
Rep Power: 9 |
Hi Amith Gubbi,
Can you please tell me how you managed to build AND use your new viscosity model? I'am working with simpleFoam, and I have implemented a new viscosity model based on the Papanastasiou regularization. But each time I try to run a case using my new viscosity model, I got an error message suggesting that my new viscosity model is not valid (attachments). Thanks in advance for your time, and have a nice week. Regards. Last edited by TemC; March 3, 2017 at 03:31. |
March 31, 2017, 02:24 |
#4 | |
Yaroslav
Rep Power: 12 |
Hi!
Here my realization of Papanastasiou regularization of HerschelBulkley. Tested for OF4.1. Use this post to implement the code. Quote:
Yaroslav |
July 28, 2021, 05:06 |
mohammad
Rep Power: 11 |
Coupling RPI wall boiling model with population balance model in Fluent | softice2006 | Fluent Multiphase | 1 | April 19, 2023 02:09 |
Herschel Bulkley model Problem | emad | FLUENT | 6 | September 12, 2018 13:35 |
Error finding variable "THERMX" | sunilpatil | CFX | 8 | April 26, 2013 07:00 |
Regarding Implementation of Hershel Bulkley Model in Viscosity correlation | Pathak | FLOW-3D | 0 | August 24, 2009 06:34 |
