custom BC not recognized when using SYSTEMOPENMPI
I made a custom BC which is running fine for serial and "normal" parallel run in OF. However, I am using a cluster in which I need change the WM_MPLIB environment variable to SYSTEMOPENMPI in order to use the proper mpi settings. When using it, and running through mpirun -np .... command, the new BC is not recognized, giving me the standard error providing me the list of available BC's.. Any idea? Thanks in advance. SOLVED: Actually, I was not the clearest I could be. I am using a beowulf cluster, therefore, I should have compiled my custom BC in all machines (boring, I know). Doing this, it worked! Regards, Lisandro Maders |
