Home > Forums > OpenFOAM Programming & Development
Reading in Pressure Values from OpenFOAM code?
Like Tree1Likes
  • 1 Post By hk318i
Old   August 4, 2016, 11:48
Default Reading in Pressure Values from OpenFOAM code?
Dominic
Verse is on a distinguished road
Hello, I've run into the problem of accessing my pressure values, from within my code during runtime.
I've been using the following syntax:
const volScalarField & p = mesh.lookupObject<volScalarField>("p");
and yet after compiling successfully, I get this error during runtime:
Name:
p
--> FOAM FATAL ERROR:
    request for volScalarField p from objectRegistry region0 failed
    available objects of type volScalarField are
0
    From function objectRegistry::lookupObject<Type>(const word&) const
    in file /home/verse/foam/foam-extend-3.1/src/foam/lnInclude/objectRegistryTemplates.C at line 139.
FOAM aborting
Aborted (core dumped)
Any idea what's wrong? I'm using foam-extend 3.1
Verse is offline   Reply With Quote
Old   August 5, 2016, 12:35
Hassan Kassem
hk318i is on a distinguished road
It means that there is no volScalarField available in the database which means that your code is trying to access it before it is created by the solver. You may included your code before createFields.
Verse likes this.
@HIKassem | HassanKassem.me
hk318i is offline   Reply With Quote
Old   August 8, 2016, 08:31
Dominic
That is indeed correct.... I realized that I commetted out that line in the beginning of my code...
Thread Tools
Trackbacks are On
how to call 'p' as pressure into my code from OpenFOAM? atmcfd OpenFOAM Programming & Development 9 March 25, 2016 18:13
static vs. total pressure auf dem feld FLUENT 17 February 26, 2016 14:04
chtmultiregionsimplefoam: different pressure values in openFoam and Fluent vasava OpenFOAM Running, Solving & CFD 0 November 7, 2014 04:35
Suggestion for a new sub-forum at OpenFOAM's Forum wyldckat Site Help, Feedback & Discussions 20 October 28, 2014 10:04
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 06:13
