LiquidEvaporationBoil & LiquidEvaporation
I'm running a test case with sprayFoam. I have used two evaporation models "LiquidEvaporationBoil" and "LiquidEvaporation". The results are different. After some investigations, I figured out, if boiling does not occurs, theoretically two models should behave the same. dMassPC[lid] in LiquidEvaporation is clear Code:
dMassPC[lid] +=kc*(Cs - Cinf) *pi*sqr(d)*liquids_.properties()[lid].W()*dt However I can not understand how dMassPC[lid] is calculated in LiquidEvaporationBoil (when there is not boiling) Code:
else |
I found some information baout the evaporation part in the "LiquidEvaporationBoil" model. It is called "The Spalding evaporation model" (Spalding (1953)). you can find more information in the following link
Spalding number in LiquidEvaporationBoil
I know the post is quite old but I have a question concerning the use of Xr in the expression:
dMassPC[lid] += pi*d*Sh*Dab*rhos*log(1.0 + Xr)*dt; In literature this expression is always written using Bm, the Spalding mass number: #mass ratio const scalar Bm=(Ys-Yc)/max(SMALL,1.0-Ys) #Molar ratio const scalar Xr = (Xs - Xc)/max(SMALL, 1.0 - Xs) Does anybody know the rationale behind this choice in OpenFOAM? |
